primary oil change
Old Apr 13, 2011 | 10:08 AM
Leftcoaster's Avatar
Leftcoaster
I know of no shortcuts for primary oil changes. My '06 manual says it should be filled up to the spring with the bike level and the only way that can be done is through the derby cover. I have re-used derby gaskets 1-2 times with no leakage issues.
You may be able to measure the amount you refill making sure it is up to the spring and then use that amount from then on. But removing the derby to inspect is a good habit to have.
Old Apr 13, 2011 | 10:30 AM
HDV-GLIDE's Avatar
HDV-GLIDE
I've been using the same gasket since 2009 and no leaks. Been off properly 8 times now.Wipe the gasket with some clean oil prior to installing it, torque the screws to to proper torque and you should be fine.
Old Apr 13, 2011 | 11:17 AM
MyFirstHD's Avatar
MyFirstHD
'06 EGC 32 oz. Still have to take the derby cover off once in a while to adjust the clutch.
Old Apr 13, 2011 | 07:22 PM
ruin66's Avatar
ruin66
thanks all. alot of info that I didn't need, but grateful to get lots of opinions. the info I was looking for, thanks to those who caught my meaning in my ramblings, was that all of the oil drains out. thanks again
Curt1953
Aug 16, 2015 03:11 PM
jbyun
Sep 7, 2011 08:40 PM
hawgsickle
Oct 28, 2009 04:05 AM
Thomto
Aug 13, 2009 09:43 PM
Globeracer
May 20, 2009 03:09 PM
