startup display question
Old Apr 23, 2011 | 04:29 PM
junglebill's Avatar
junglebill
Default startup display question
Another noob question, but honest... I couldn't find a thread that already discussed it!
I throw the kill switch to "On", then select ignition.....sometimes I get a full display of all the lights and the speedo goes to max and back down, other times....all I get is the "check engine" light which goes out and I hit the start button.
Why two different displays? Is this an glitch or gremlin I need to track down?
She runs great and I hope everyone got as great a ride today as I did, the weather and roads were fantastic here in western NC!
Thanks!
Old Apr 23, 2011 | 04:34 PM
dbell66253's Avatar
dbell66253
I used to get the same thing in my 07, I had the dealer flash the ECM and the problem went away.
Old Apr 23, 2011 | 08:14 PM
junglebill's Avatar
junglebill
Sorry, is flashing the ECM something that requires special equipment?
Old Apr 24, 2011 | 02:14 PM
dbell66253's Avatar
dbell66253
Not 100% sure, but I believe it is, the bike was still under warranty, I took it to the dealer and explained the problem, and that's the answer I was given. Also sometimes while riding all my instruments would go dead until I stopped and turned the bike off and restarted it again. It took the dealer less than 10 minutes to fix the problem.
Old Apr 24, 2011 | 03:33 PM
iclick's Avatar
iclick
If you want to flash to an updated firmware you'll need to take it to the dealer, who may not charge you (mine doesn't). I don't know what year-model you have or what FW you have installed, but there have been at least four FW versions for the '07. I would pick the latest one for your year-model.
Old Apr 24, 2011 | 04:07 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Is she under warranty if so take it to the dealer and have them figure it out
Old Apr 24, 2011 | 04:57 PM
skratch's Avatar
skratch
i had the same thing happen to me. in my case, the speedo reset switch had gone bad (contacts were sticking), so it thought that i was putting it in diagnostic mode. dealer replaced switch under warranty and it hasn't happened since.
buzdean
2014-2024 Touring Models
39
Oct 3, 2014 10:43 AM
CG1884
Jun 20, 2011 08:30 PM
CandyMaker
Jun 16, 2009 07:12 PM
turtleman57
Apr 30, 2008 09:47 PM
safields
Sep 22, 2007 08:12 AM
