Looking for touring bike, what to avoid?
5th gear whine in 07-09 bikes - in 10 they changed the gear.
07 did not have the IDS standard - in 08 they made them standard.
08 was the first year for the Brembo brakes - Major improvement!
Some 05 bikes had oil consumption problems related to valve seals.
Excellent summary 89FLHT
lp
- Yes, big improvement w/09 & up frame.
- Pretty much after 2006 - most touring class HD's went to EFI.
Good luck w/your search. I say get a Street Glide, but I'm bias...
The frame was changed - so seats, body panels, fenders and aftermarket things are bolt ons vs doing some work to make them fit A lot of parts can be "made to work" on bikes older than 97 though, just requires fabrication at times. On the older bikes things like a wiring harness or inner and outer fairing / gauge clusters are a bitch to locate new, most times it is off to ebay for that stuff or you make or retrofit your own stuff.
Is the torrington bottom end good or bad? -good
Throttle by wire would add another layer of complexity, but if dependable, may not be too bad. Anyone have issues with it?
Some have had problems - I do wish mine had cables and a carb in all honesty, just beacuse I'm familiar with them and they are simple to me, but I was willing to give it all up to get ABS brakes- it's the main reason I wanted a new bike.
I would prefer the 6 gallon. Can that tank be fitted on older models?
Can be done - GBrown on this site is retrofitting a 6 gallon to his 91 currently. It is not a bolt on, but it can be done with a mix of oem and aftermarket parts.
Have fun hunting !!!!
Find a low mileage o2/03, when the bike hits 25K have the cam tensioner upgrade done, there are slip in "cassettes" for a 6 speed for the bike, personally I have not found the need for a 6th gear on my 03, and trust me if I thought it needed one I'd spend the money without hesitation.
As with any used vehicle purchase it is buyer beware, service history, condition of the bike, attitude of the owner etc will give you clues. Look at what his other vehicles look like when you go to check the bike out. If the are neglected chances are the bike has been too.
BL, if you get the 10 or 11 Limited you will be
