New Bars = No Throttle snap
Old Apr 27, 2011 | 07:06 PM
JoshuaCannon's Avatar
JoshuaCannon
Default New Bars = No Throttle snap
Installed the new bars, the indy said the cables weren't to long. I am thinking he is wrong, there is a lot of slack behind the fairing. Can long cable cause the throttle to not snap back when I release it or is there another issue? Thanks guys
Old Apr 27, 2011 | 07:10 PM
dawg's Avatar
dawg
What bars you got and what length cables?
Old Apr 27, 2011 | 07:14 PM
JoshuaCannon
I have the Ergo Standard bars now, I am not sure what aftermarket bars were on there and Im not sure the length of the cables. They are aftermarkt because they are braided, and I know they arent the stock length because the old bars came way back and down.
Old Apr 27, 2011 | 07:15 PM
Standard's Avatar
Standard
Sounds like they are just not adjusted properly.
buggy's Avatar
buggy
make sure they are not twisted or binding up, they need to make a gentile curve . Lube them and make sure they are adjusted right.
Old Apr 27, 2011 | 07:53 PM
103 sedona orange's Avatar
103 sedona orange
From what I remembered there is a certain way adjust them . Check your Svc Manual. You might do a search on this site. The lenght should have nothing to do with how the work IMO
Old Apr 27, 2011 | 07:56 PM
BBStacker's Avatar
BBStacker
+1 as stated previously bust out the service manual and adjust them per that. Make sure you check center, left side and right for binding when you turn the bars.
Good luck, have fun.
Old Apr 27, 2011 | 07:59 PM
2002EGlide's Avatar
2002EGlide
I'm in the process of putting 16's on my bike now and found if they are not properly adjusted the throttle will not snap back.
Old Apr 27, 2011 | 08:28 PM
fabrik8r's Avatar
fabrik8r
Yep, adjustment. I tightened the idle cable too much and the throttle not only wouldn't snap back, it would not return on its own, had to manually roll it forward.
CZshooter
Jul 27, 2015 09:18 PM
Van Buren
Mar 25, 2014 03:31 PM
transdel
Jul 18, 2013 04:10 PM
Dominic2316
Jun 21, 2012 05:02 AM
loosnut
Jul 1, 2011 09:40 PM
