bad gas
Old May 1, 2011 | 08:32 AM
mikeflhr10's Avatar
mikeflhr10
Default bad gas
Got the bike put back together, drove seven miles on fumes to get gas filled up made it one block stopped running. Bad day drain gas and start. over two tank still not running perfect any ideas o yea 10 flhr stage 1
Old May 1, 2011 | 08:35 AM
1flhtk4me's Avatar
1flhtk4me
May have something to do with putting it back together?
What did you do?
Old May 1, 2011 | 08:40 AM
mikeflhr10's Avatar
mikeflhr10
Paint and chrome nothing else ran perfect to gas station
Old May 1, 2011 | 08:42 AM
brgtr3's Avatar
brgtr3
Bad gas? Well, I'm thinking it might have been the refried's. Next time, lay off the burrito's!
Old May 1, 2011 | 08:58 AM
EP50's Avatar
EP50
http://www.youtube.com/watch?v=3B5Jnho8dTc
Old May 6, 2011 | 04:21 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Check the filter in the tank may need to be replaced
Old May 6, 2011 | 05:19 PM
piasspj's Avatar
piasspj
Did you get fresh gas at a different station?
Check any electrical connections you disconnected (may be a connector didn't get mated properly or a contact got pushed out also check any place where a harness or fuel line may be pinched or rubbing.
Old May 6, 2011 | 05:42 PM
omgtkk's Avatar
omgtkk
If you ran the bike almost dry you probably sucked up some debris that was sitting in the bottom of the tank, or some moisture that may have settled there..Change your fuel filter.
Old May 6, 2011 | 05:50 PM
dbell66253's Avatar
dbell66253
+1 when ever you go to the bottom of the tank, there's a chance of collecting the debri, plus what was in the last gas that made it bad? Good chance some of it still in your filter.
birdmandave
Apr 27, 2014 08:14 PM
streeteagle
Jul 5, 2012 08:50 PM
ua72
Southeast
Apr 10, 2011 10:40 AM
assclown
Jul 26, 2008 03:46 PM
sonic
Jun 21, 2008 10:26 AM
