Spark Plugs
Old May 3, 2011 | 10:12 PM
The Q's Avatar
The Q
I use NGK Iridium plugs.Used them in my two Sportsters and now in my Street Glide.
Old May 3, 2011 | 10:17 PM
emwolb's Avatar
emwolb
i use i think the 6r12g's. the g means that it has a coating that's not supposed to seize in the threads, i don't know why i don't just use the 6r12's because i use the silver anti sieze stuff on the threads anyway. stock harley plugs work great. don't buy into any of that platinum, iridium, or unobtanium crap, it's just hype. standard harley plugs work fine.
Old May 3, 2011 | 10:18 PM
Harleyboyddk's Avatar
Harleyboyddk
Denso Iridium plugs, superior quality. Platinums are great also. Nothing wrong with oem plugs if you are on a budget. Won't last as long as the the exotics.
Old May 3, 2011 | 10:22 PM
kdfcogwheel's Avatar
kdfcogwheel
I use PulStar He1i. Saw a small improvement in fuel mileage.
_________________________
2010 FLHTK
Old May 3, 2011 | 10:25 PM
02ULTRA's Avatar
02ULTRA
Originally Posted by 1Harleyrdr
Just installed E3 plugs 600 miles or so ago, fuel knock down mileage went up a bit strange. I dont know the part number.
I have been interested in trying these E3 plugs, I may put them in and try them for my up coming 4,500 mile trip in a couple weeks.
Old May 3, 2011 | 10:59 PM
slowburngooch's Avatar
slowburngooch
Just changed mine @ the 20,000 mi service.
Installed the SE platinums at first, along with the 10mm wires. Shortly after, I noticed the check engine light was on. Talked to the parts guy at my local dealer, he said the stock 6r12 is all you need unless significant motor work is done.
I put a new set of stock plugs in and she runs great, light went out and codes cleared.
Note** when I removed the platinum plugs and checked the gap they were a little tight (too close of a gap), so not sure if it was improper gap causing the code.
Bottom line: the stock plugs are fine, just make sure the gap is within spec (.040 is ideal) whatever you use
Old May 4, 2011 | 04:38 PM
DamifIknow's Avatar
DamifIknow
Thanks guys. Man I love this place.
nhhdrider
Jan 17, 2014 11:30 AM
harleyglen
Oct 10, 2013 10:51 AM
ranger50
Oct 6, 2010 06:20 AM
bob53
Sep 27, 2006 05:23 PM
Nevar
Exhaust System Topics
13
Mar 16, 2005 05:44 PM
