Saddlebag Lid Spoilers Install - 2011 RGC
Old Aug 23, 2012 | 06:53 PM
wachuko's Avatar
wachuko
Cool
Originally Posted by Pioneer74
Subscribed
I hope this is what you were looking for.
Old Aug 23, 2012 | 07:26 PM
Pioneer74's Avatar
Pioneer74
Sure is. They are on my winter mod list.
It keeps growing.
Old Mar 29, 2013 | 08:44 AM
Papi's Avatar
Papi
If the lights are to dim you can send them to Radiantz and have them install
Brighter LED's in it
Old Mar 29, 2013 | 10:39 AM
Stang951's Avatar
Stang951
It would be nice if someone made replacement module.
Old Apr 14, 2013 | 09:11 PM
bolton's Avatar
bolton
Stage I
Thanks man, I just finished the install on my 2013 Street Glide [Chrome yellow pearl].Used your step by step and it was a breeze.I may look for some water-tight connectors to put between the bag and seat so I won't have to remove the seat to remove the bag for wheel cleaning etc.. thanks,Mike
Old Apr 14, 2013 | 09:58 PM
Lonnie LaFever's Avatar
Lonnie LaFever
Great write up.
Old Jun 15, 2016 | 11:31 AM
ProspectNY's Avatar
ProspectNY
Start with a small drill bit... instructions mentions a 1/16" drill bit... I went with a 1/8" - Then drill with a 9/32"
Repeat on the other side and then remove the templates and insert the wires in the middle hole... you will need to insert each wire (two at the most) at a time as all three pins will not go in at once...
Use the rubber washer and metal washer with the 3/16" bolt and fix the spoiler in place. You will have to press a little to get the rubber gasket to compress.
Drill the hole on the saddlebag. Instructions asks that you drill a 3/8" hole in front of the shock absorber area, 2" from the lip of the saddlebag.
Once you have drilled the hole on both sides, insert the rubber grommet in the hole.
same drill... insert the wires, not all pins will go in at once, so do it one at a time...
Insert the pins in the plug... White in 1, Red in 2, Black in 3
Remove the seat... search for the connector. Mine was in the middle of the bike but a little towards the left side. It was plugged with a rubber cap. Remove the rubber cap, insert the female end from the splitter. Then insert each of the plugs from the lights of the spoilers into the splitter cable. Use the provided tie wraps to organize and hold the wires in place. I forgot to take photos of this... will take the seat out, snap a few and update the thread.
Test that everything works... install the seat back. Sit back with your favorite install drink and admire your work.
Hey. I'm trying to remove the electrical connections from the black connector where it disconnects from the bike to remove the saddle bag. Any ideas on how?? I purchased a new lower bag and am reusing the old lid with the spoiler. But can't figure out how to get these wires out of the connector. I flipped up the little black tab, but don't want to just yank on the wires to get them out. Any help would be appreciated. Thanks! Great write up too!!
Old Jun 15, 2016 | 12:24 PM
wachuko's Avatar
wachuko
Get a tool set like this one... or a very small and thin screwdriver, or a needle... but best just to get these tools to do the job easier... knowing how the terminals are inserted into the plug housing, you insert the right tool into the slot (on the top side where the clip is) and the toll pushes down on the clip, letting you slide the connector out... hope that makes sense.
Old Jun 15, 2016 | 12:27 PM
wachuko's Avatar
wachuko
Here... found a video
Old Jun 15, 2016 | 04:05 PM
Stang951's Avatar
Stang951
Has anyone found smoked lights for the spoilers. They came out with them for the 14 up, but cant seem to find ones for the bikes through 13.
ThePaintPirate
Jan 7, 2019 09:46 PM
wachuko
Jul 10, 2017 12:09 PM
wachuko
Oct 22, 2013 09:14 AM
fathertime
Apr 13, 2008 06:50 PM
