2 streetglide questions
Old May 4, 2011 | 08:50 AM
traveler's Avatar
traveler
Default 2 streetglide questions
2 quick questions on Streetglides, please.
I have done a search, and having a hard time finding what exactly I am looking for
If I switch to a 21" wheel in the front and an 18" in the rear, doesn't that throw the speedo off? I'm assuming the speedo is reading off the back wheel....and would only stay correct as long as the wheel is the exact same diameter.....
What exactly do you have to do with the stock front fender to keep it from rubbing? Do you slot the holes? That "Native bagger" website talks about drilling out rivets and bolting their system on....doesn't sound good to a guy like me who doesn't want to start repainting fenders. I'm guessing once you tape the rubber line over the tire and put the fender on, you can see what needs to be "augered out". Again, paint concerns.
Any help would be appreciated.
Thanks,
~Joe
Old May 4, 2011 | 08:54 AM
slothy's Avatar
slothy
as for the native baggers, pauls kit lets you lower the fender onto the tire better - but as you noticed requires alittle more work. when i did a 21 on my stock fender i just had to drill the back hole out some to tile fender forward and it worked.
as for the speedo - yes it will change if the tire is much bigger 1-2mph max - the stock setup on my 11 was off about 3-4 mph faster when checked with gps
Old May 4, 2011 | 09:02 AM
traveler's Avatar
traveler
cool, thanks.
I wonder if recalibration is possible?
Is the speedo reading off of the front or rear wheel?
~Joe
Old May 4, 2011 | 09:09 AM
slothy's Avatar
slothy
well with a bigger tire it would correct the speedo more so if you bike was reading faster then gps.
Old May 4, 2011 | 10:02 AM
Northbound Southerner's Avatar
You can adjust spedo calibration with the new Power Vision tuner. Other tuners may be able to do this as well.
Ston
Shovelhead
Jul 16, 2017 11:54 AM
chadepperson99
Mar 17, 2015 04:52 PM
Ignitor
Wheels/Tires
Mar 7, 2013 11:12 AM
yank
Sep 20, 2012 05:06 AM
mopar7
Nov 24, 2007 06:48 PM
