Ohlins set up on Streetglide
Thanks in advance.
Bike: '07 SG
Weight: 170 lb.
Preload: Preset by Motorcycle Metal at lowest setting . Perfect loaded or not, no need to change.
Rebound: Non-adjustable
Impressions: Excellent ride and handling. Strongly recommend for a similar setup.
No they have not changed. This is what happened to me. I installed the 3-3 and backed the dampener to the end and started counting the clicks to make sure they are both the same. Apparently when you turn them to the end you have to do it with a feather light touch, if you snug them down, they will break. Not actually broken, they still work, but the waffled washer inside that is used as the tension spring will get bent out of shape and you will not feel the clicks anymore, although the adjuster still works. Howard said I cranked on it. I did not, I only hand snugged it down, I didn't know until after the fact that you have to use a FEATHER LIGHT TOUCH, and I do mean feather light. Howard called Ohlin for replacement parts, Ohlin wanted to charge me (not Howard's regular contact), but Howard waited for the guy he usually deals with to be there and got the parts for free. They are now fixed and in the mail on their way back.
So everyone be very careful when adjusting the dampeners (black ***** on the bottom). Turn them VERY lightly, when they stop, that is it, do not make sure by adding a little more pressure.
I do not yet know how I will like the Ohlins, but I have to say here, I am a little concerned about having something on my bike that brakes with anything more than a feather light touch. I see problems in the future. I should probably put a warning label on them so no tech or friend touches them. Nothing on a motorcycle should be that delicate.
