2007 FLHTCU Performance increase
Old May 5, 2011 | 03:21 PM
FlyinLow07's Avatar
FlyinLow07
1st Gear
Default 2007 FLHTCU Performance increase
I just installed Rinehart Slip-ons and SE High Perf Air filter kit on my '07 with 16k miles, had the bike Dyno'd and ECM remapped at local dealership. If I'm reading the Dyno print-out correctly I increased HP from 66.89 to 75.79 (8.9 hp gain) and torque from 78.55 to 87.02 @3500rpm (8.47 ft lb gain). I found specs for '07 FLHTCU online indicating stock performance was 92.6 ft lbs torque @ 3500 RPM. I'm guessing the 16k mileage on the engine was the culprit decreasing my torque from indicate 92.6 to 78.55. Depressing that my $ investment didn't even restore my torque to the original 92.6 ft lbs. Oh well, I love the way it sounds, accelerates and plains out on the hiway. Your thoughts on the numbers? Thanks.
Old May 5, 2011 | 03:26 PM
carpetride's Avatar
carpetride
That 92.6 ft lbs is NOT measured at the rear wheel. The dyno # is. Different dynos give different results. The main thing is you picked up a decent power increase. Go ride.
Old May 5, 2011 | 03:27 PM
SICKBAGGER's Avatar
SICKBAGGER
I think HD post numbers at the crank and not the rear wheel like your dyno print shows. Your probably well over stock cheer up ride it who cares about a numbet!
Old May 6, 2011 | 07:57 AM
FlyinLow07's Avatar
FlyinLow07
1st Gear
Thanks for the replies and knowledge. Don't get me wrong, I'm HAPPY with the results. Just needed a bit of help with the numbers. Thanks again.
Old May 6, 2011 | 10:44 AM
iclick's Avatar
iclick
As has already been suggested, don't give any credence to HD performance specs. Your numbers look good.
impala
Jan 20, 2008 06:18 PM
grandpawmoses
Apr 13, 2007 05:02 PM
flashprez
Oct 29, 2006 10:11 AM
RjCapp
Exhaust System Topics
Oct 28, 2006 02:09 AM
SFTail06
Jul 5, 2006 03:39 PM
