tork spec for ultra
Old Oct 25, 2006 | 03:12 PM
2buxleft's Avatar
2buxleft
Default tork spec for ultra
I'm replacing rear shocks and don't have a manual yet[sm=icon_rtfm.gif], so could I get some help with tork specs for a 06 ultra[sm=thanx.gif]
Old Oct 25, 2006 | 03:19 PM
bountyhunter's Avatar
bountyhunter
Default RE: tork spec for ultra
Just crank em tight with a 1/2" drive rachet.
Old Oct 25, 2006 | 03:40 PM
2buxleft's Avatar
2buxleft
[sm=wtf.gif] Now why didn't I think of that ?.........Oh, I know now..... it's because I have a tendency to OVER tighten for fear of coming loose while on the road
Old Oct 25, 2006 | 05:38 PM
SteelCityScooter's Avatar
SteelCityScooter
from the manual:
Caution: Never lay the shock absorber down. Always keep the shock absorbor upright in a vertical position. laying the shock absorber down with the air line removed can cause the oil to drain out the compression fitting.
Any loss of oil requires replacement of the shock absorber
[ul][*] 1. Install lockwasher and flat washer on the lower shock mounting bolt. Insert bolt through shock bottom bushing.[*] 2. Apply two to three drops of Loctite Medium Strength Threadlocker(blue) to threads.[*] 3. Start bolt into rear swingarm mount. Tighten bolt to 35-40 ft-lbs. (47-54 Nm.)[*] 4. Install lockwasher and flat washer on the upper shock mounting bolt. Insert bolt through shock upper bushing.[*] 5. Apply two to three drops of Loctite Medium Strength Threadlocker(blue) to threads.[*] 6. Start bolt into frame boss.. Tighten bolt to 35-40 ft-lbs. (47-54 Nm.)[*] 7. Insert air tube into compression fitting until it bottoms. Gently tug on tube to verify that it locked in place.
NOTE. If replacing both shock absobers remove and install the other shock at this time.
[*] 8. Pressurize rear suspension system and check for leaks. For the correct air pressure, see section2.18 REAR AIR SUSPENSION.[*] 9. Install rear saddlebags. See Section 2.26 SADDLEBAG INSTALLATION.
[/ul]
You can find the rear correct pressure in your owners manual.(I'm not typing that out too)
Old Oct 26, 2006 | 01:57 PM
2buxleft's Avatar
2buxleft
SteelCityScooter............. Thanks that is all Iwas looking for...........I can now complete my work with out fear of being "Half-A$$'d)[sm=escape.gif]
Old Oct 28, 2006 | 02:23 PM
rdam's Avatar
rdam
OK....I'm buying a manual. I think I saw a nice price at Surdyke's on-line. I love step-by-step idiot-proof instructions.
BKSinAZ
Mar 27, 2016 08:04 PM
TriGeezer
16
Oct 4, 2015 05:04 AM
rocky5
May 3, 2013 12:09 PM
GEESE
Jul 25, 2010 09:34 AM
rockon
Nov 6, 2008 08:24 AM
