Cam change question
Old May 6, 2011 | 11:38 AM
V-RoyD's Avatar
V-RoyD
Default Cam change question
I’m wanting to swap cams on my 10 FLHX, stock 2-1 head pipe w/ gutted cat, D&D slipon, SE a/c, H-D download. I plan on doing the work myself. Has anybody had experience with Woods 44 mag cam? What can I expect with this cam in my 96” motor? Reason I’m considering this cam is it seems close to the SE211 which my local dealer recommends a lot and I can get this very low mileage used one from a friend. Input is appreciated. I'm doing the swap myself.
Old May 6, 2011 | 12:41 PM
07RoadHawg's Avatar
07RoadHawg
I'm thinking about using that cam on a 107". Sure you could use it in a 96, but IMO you would lose quite a bit on the bottom end with the long duration and intake valve timing. I really wouldn't use either one in a stock compression 96", but that's just me.
Old May 6, 2011 | 12:48 PM
Mike's Avatar
Mike
One of my favorite woods cams, but you need about 10.5 compression to run it. Much better cam for a stock 96 is the SE255. You can find those everywhere for around 150 bucks.
bedelman10
Engine Mechanical Topics
98
Jul 21, 2016 07:00 PM
Wmitz
May 17, 2014 08:47 PM
chunks
Mar 27, 2012 05:05 PM
SmittyFXDL
Mar 19, 2012 06:54 PM
rickrides
Exhaust System Topics
May 25, 2008 03:17 AM
