Oil Filter
Old May 7, 2011 | 08:11 AM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
Amsoil oil & K&P engineering reusable oil filter.
Old May 7, 2011 | 08:13 AM
bwana1's Avatar
bwana1
Mobil1/S&S make a filter that is 1/8" less in diameter than the HD filter, part # 31-4101. Much easier to get past he crank sensor plug.
I use the long K&N filter on my racin N'ster to get a little more capacity.
Old May 7, 2011 | 08:14 AM
atrain68's Avatar
atrain68
Originally Posted by troop
Like oil, oil filters also stir up the pot Champion Labs makes the H-D filter proprietary to their specs. Champion Labs also makes the corresponding size in a Walmart Supertech filter for $3 The Walmart filter meets H-D's oem specs. The question is do you want a $3 Walmart filter on your $20k bike?
If it works then yes.
Old May 7, 2011 | 08:34 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Stock HD filter with the bypass.
Old May 7, 2011 | 09:08 AM
iwillfixthem4u's Avatar
iwillfixthem4u
I have a Harley extended warranty, so I will keep using OEM Oil (SYN3)and filter to keep it all in Harley's court. If there is a issue I want the finger to point in one direction.
Old May 7, 2011 | 09:30 AM
troop's Avatar
troop
I'm using one now. And they do have a by-pass for another poster ...
Old May 7, 2011 | 09:34 AM
DPete's Avatar
DPete
HD black cause I'm to cheap for chrome. Many aftermarket filters are not 5 micron.
Old May 7, 2011 | 09:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Any filter designed to work on a Harley Evo or TC will have a bypass (not talking about racing filters).
TC filters will also have an anti-drainback valve.
Evo filters don`t need to have an anti-drainback valve because the filter is in the oil return path.
Old May 7, 2011 | 10:04 AM
cuda67bnl's Avatar
cuda67bnl
Got a part number for that $3 filter?
Old May 7, 2011 | 11:06 AM
Wassup8687's Avatar
Wassup8687
I've been sticking with the Harley filter.
