DC COAX Battery HarnessDC harness with coax connector and waterproof fuse holder, 15 amp fuse.
Femail:6 SAE Connection to DC COAX
Jack AdapterCoax jack adapter cable with 6 inches of 16 AWG wire and SAE connector. For connecting heated clothing with a coax plug to a SAE Heat-Troller.
and
TM Heat-troller AdapterNEW for 2011Use your Heat-troller on other heated apparel$9.95 Suggested Retail
Wouldn't you then need an adapter to change your heated gear to fit the new plug?
The same adapter I use for my Battery Tender works with my heated vest.
I'm surprised Harley doesn't put power sockets on its touring models. The cigarette lighter socket in the bat wing is not convenient for battery charging or heated gear. BMW has been installing 12V sockets since the early 80s. This is where I got the idea. Some BMW touring models have two sockets, one for the rider and passenger.
