Air Shock Question
Old May 8, 2011 | 10:38 AM
KDUBYA's Avatar
KDUBYA
Default Air Shock Question
2007 FLHX - Should I adjust the air pressure in the scocks when adding a tour-pak or a passenger or both? If I should, what should it be?
Old May 8, 2011 | 10:40 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
there is a chart in the owners manuel,it gives recommended pressure for different loads.be careful with advise here different models use different pressures,be very carful when adding air the shocks are easy to overfill and blow the seals.
Old May 8, 2011 | 10:47 AM
1flhtk4me's Avatar
1flhtk4me
If you add any amount of extra weight better to add some air.You can experiment and find out what pressures suite your needs.
Old May 8, 2011 | 10:50 AM
NDBadlands4-2's Avatar
NDBadlands4-2
In the owners manual are all the answers. It does make a difference. I usually run very little air in the things. Last year I took the wife and 3 deays worth of gear on a trip. We kept bottoming out the shocks on any little bump. Then I remembered why. Aired them up and no more issues.
Old May 8, 2011 | 11:25 AM
nvsteve's Avatar
nvsteve
I add about 5 pounds over what the owner's manual says. Seems better. Be sure to check your manual as the different touring bikes of the same year have different pressures.
Old May 8, 2011 | 11:44 AM
harley0711's Avatar
harley0711
on my 04 I ride two up most of the time... I played with the air in those rear shocks and really never could find something that worked well, finally broke down and got some Werks and have never looked back.. good luck on your quest - IF you get tired, there are other options
Old May 8, 2011 | 12:56 PM
KDUBYA's Avatar
KDUBYA
What are Werks?
Old May 8, 2011 | 01:15 PM
Stiggy's Avatar
Stiggy
Originally Posted by KDUBYA
What are Werks?
"Works" is an aftermarket shock company that makes improved systems for motorcycles, But if you own an '09 and later you have the new HD 50 lb shocks that are much improved over what we rode on from '08 and earlier.
Just play with different pressures 'til it feels like it did before you added weight.
Old May 8, 2011 | 02:38 PM
FLHTCU Owner's Avatar
FLHTCU Owner
What are Werks?
http://www.phatperformanceparts.com/...tracker-hd.htm
kjkustoms
Feb 10, 2020 07:29 AM
Mborras1
Feb 21, 2019 02:21 PM
rattlebones
Aug 23, 2010 06:29 PM
fiddlinfool77
Jun 9, 2007 08:50 AM
dchoran
Mar 28, 2007 11:22 AM
