Stalling at idle
Old Feb 2, 2017 | 02:45 PM
cweiss's Avatar
cweiss
My 07 streetglide did the same thing. replaced TPS sensor (35ish dollars) and cleaned out the IAC valve which is under the tank right near the TPS with some intake cleaner.
Old Feb 2, 2017 | 02:58 PM
Diogenetic's Avatar
Diogenetic
Stage III
Default Does a Carburetor have a TPS sensor?
I have a carberator, does it have a TPS sensor? I don't think it has an IAC valve. I looked in shop manual, didn't see it there.
Old Feb 2, 2017 | 04:30 PM
kojak's Avatar
kojak
Did you check your idle adjustment on your choke?
Old Feb 2, 2017 | 04:40 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Only once has my 2004 FI done that. It was a dose of bad fuel. The idle is set at around 1000 and is pretty sensitive to incorrect things. The iac valve is pretty rugged except for someone spraying a lot of cleaner up into it. Washes crud up past oring in servo motor. If the tank filter gets stopped up, that will kill the idle most of the times but unless you dump a lot of gas from dirty containers, the filter will last forever.
VHinch
Jun 22, 2020 11:54 AM
Bu11Dawg
Aug 20, 2012 06:23 PM
Bushy
Sep 22, 2010 08:59 PM
dingo67
Exhaust System Topics
Dec 15, 2009 09:20 PM
hullinone
Apr 23, 2006 11:24 PM
