Compensator woes solved
Old May 14, 2011 | 09:29 AM
Classic Rider's Avatar
Classic Rider
Talking Compensator woes solved
Installed the sc compensator on my 08 ultra yesterday. No more grinding on starts and no cluncking on shut downs. I wish the MOCO would address this problem, since so many of us are having it.
Old May 14, 2011 | 09:32 AM
lionsm13's Avatar
lionsm13
How did you do the install of the SE COMP?
I don't have the issues that you have, but mine surges forward on start up a few inches..
Old May 14, 2011 | 09:35 AM
Classic Rider
There was a thread on here a while back. Told exactly how to do it, wasn`t that hard to do, if you can follow instructions.
Old May 14, 2011 | 09:51 AM
Dionicio's Avatar
Dionicio
Surging forward would'nt be a compensator problem. On cold startup put the bike in neutral. If it surges foward when warm adjust clutch. FWIW, I always start mine in neutral with the clutch lever pulled in. I hear that starting in Neutral is easier on the starter also, don't know for sure.
Old May 14, 2011 | 10:13 AM
lionsm13's Avatar
lionsm13
Yeah you're right.. I always start my bike in gear w/the clutch engaged as I don't wanna hear the "clunk" into gear. When the bike is started after it is warmed up it doesn't surge..
Old May 14, 2011 | 12:06 PM
Guy2008Ultra's Avatar
Guy2008Ultra
Originally Posted by Classic Rider
Installed the SC compensator on my 08 ultra yesterday. No more grinding on starts and no clunking on shut downs. I wish the MOCO would address this problem, since so many of us are having it.
I have waited, at 14K it needed it they won't fix the "normal noise"
Old May 15, 2011 | 08:12 AM
DocHarley's Avatar
DocHarley
Old May 15, 2011 | 08:17 AM
lionsm13's Avatar
lionsm13
Originally Posted by DocHarley
That took a lot of effort.. didn't it?
Any suggestions then bright one?
Old May 15, 2011 | 08:27 AM
atrain68's Avatar
atrain68
Cranky this morning?
Old May 15, 2011 | 08:30 AM
atrain68's Avatar
atrain68
Actually, I'm thinking about switching to the SE compensator this season. I'm not getting any clunking or grinding, but I want to see if the SE comp will remove any slack from the drive line. Also some added insurance since the stock compensator is a known issue.
