quick oil change question
Old May 19, 2011 | 08:51 PM
Livinfastforword's Avatar
Livinfastforword
It was definatly oil that came out slow.. The manual says do not remove but doesnt say what it is, Or what it drains.. This is the 1000 mile break in none of the oil was really dark it all lookd about the same.
Old May 19, 2011 | 08:55 PM
cmcsns's Avatar
cmcsns
From: Beverly Hills, Fl. Swimmin pools. Movie stars
This may be helpful!
Old May 19, 2011 | 09:01 PM
Iceman24's Avatar
Iceman24
You just removed the tapered pipe plug which is an inspection port in the oil pan (no worries). Need to either go buy yourself an oil-temp gauge (perfect time to install), or coat w/red locktite & re-install...
Old May 19, 2011 | 09:11 PM
rydahog's Avatar
rydahog
Default your oil hex plug answer..
dont know if your going to like this or not,,but removing this hex bolt is not a good thing,
Part of the manufacturing. Messing with it can cause you to split the oil pan. Many have found out the hard way not to mess with.
It is not a HD plot to stop you from draining out all of your oil. proceed with caution on reinstallation of this bolt..hope that helps...
Old May 19, 2011 | 09:12 PM
imskier2's Avatar
imskier2
Yes that is what it is the place where it is the optimum place to read the oil temp, there is no seal so you have to use some kind of pipe sealer on the threads.
Old May 19, 2011 | 09:29 PM
qtrracer's Avatar
qtrracer
And that sealer aint red loctite.
Old May 19, 2011 | 09:34 PM
AbnMP13's Avatar
AbnMP13
Awesome!
Old May 19, 2011 | 09:37 PM
Livinfastforword
Thank you very much that is definatly what it was.. I did not use sealer. I guess I will get some silicon or something of that nature tommorrow and take it back off again and seal it
Old May 19, 2011 | 09:48 PM
RICHIEMACK's Avatar
RICHIEMACK
Well now you know and learned something new
Old May 19, 2011 | 10:39 PM
Then Came Bronson's Avatar
Then Came Bronson
Correct.
I just looked it up in my service manual (2010 Touring), and you want to install that tapered pipe plug (or hex plug) with Loctite Pipe Sealant with teflon 565 (P/N 99818-97). Tighten to 18-22 ft-lbs (24.4 29.8 NM).
