2002 Road King Not Getting Fuel
Old May 20, 2011 | 08:02 PM
RD WOYER's Avatar
RD WOYER
Default 2002 Road King Not Getting Fuel
2002 Road King was out riding was running great and all of a sudden died , it would crank over but wouldn't run so we had to trailer it home .
We have good compression , good spark , good battery voltage , 60 psi fuel pressure to the back of the throttle body but no fuel from the injectors with the key on or when cranking .
With a spray bottle of fuel spraying into the throttle body you can get the bike to run .
Ive checked the fuses with a test light , cleaned the ecm and connectors with electromotive , ive been trying to diagnose this thing for the last 3 days after work with no luck .
Im not sure where to go from here ? Any help would really be appreciated .
Old May 21, 2011 | 07:55 AM
Mike T's Avatar
Mike T
Something in the ECM circuit has failed, check for codes.
Old May 21, 2011 | 08:20 AM
Bodean46's Avatar
Bodean46
My 01 did the same thing. PCIII fried and took out ecm fuse.
Old May 21, 2011 | 08:54 AM
RD WOYER's Avatar
RD WOYER
Just went out and checked the codes :
23 Front injector open/low , Front injector high
41 CKP sensor intermittent , CKP sensor synch error , Ignition switch open/low
24 Front ignition coil open/low , Front ignition coil high/shorted , Front cylinder combustion intermittent , Front cylinder no combustion , Front cylinder combustion intermittent
25 Rear ignition coil open/low , Rear ignition coil high/shorted , Rear cylinder combustion intermittent , Ignition enable output high , Rear cylinder no combustion
Old May 21, 2011 | 01:53 PM
RD WOYER's Avatar
RD WOYER
Hey guys been out in the garage most of the morning and finally found the problem , one of the wires on the front connector for the injector had broke . Went to the local HD , spent $3 bucks on two prongs , soldered them on and lengthen the wires so they weren't so tight like before . Buttoned it all up and she fired right up .
Man was i relieved .
Hdlebanon
Feb 16, 2017 07:59 AM
madaug
Feb 28, 2015 08:01 PM
rw1050
Jul 30, 2012 12:59 PM
02EGC52802
Jun 10, 2012 03:56 PM
zenwarrior
Sep 6, 2006 06:16 PM
