Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I installed a pc3 to my road king 2007 , it had a rough start and it is working only on the rear cylinder , i checked the ignition , the ignition of the first cylinder is very low , any help please !!!??
Is this a used PC3USB?
Reliability of those units are questionable. Some seem to last forever and some die over time.
Remove the unit. Does the bike run normal? If so you are possibly the owner of someone else's failure.
Bob
Its used pcusb3 , i removed it and still working on 1 cylinder , maybe the ecm is damaged? Or its maybe a coil problem ? I replaced the ignition wires and still the same problem ,
If it works with the PCIII removed, then the PCIII is bad. You say it is a used unit? How do you know it is good? You can send it back to Dynojet, and they will test it, though I don't know what they would charge you to do that.
Don't reinstall the PCIII until you figure out your ignition issues. Make sure the battery is fully charged. Check for trouble codes.
Some of the earlier twinkies had a problem with the front injector harness being too short, but I thought they had that figured out by 2007. You can do a wiggle test on the front injector wire to see if it is shorted though. You should check for spark in the front cyl.
