Oil in higher temperature areas?
Old May 21, 2011 | 03:50 PM
kingkingking's Avatar
kingkingking
I run Penrite Sin 10 10-70. Not sure if you can get it in the states, I would expect so.
http://www.penriteoil.com.au/pis_pdf...OCT%202010.pdf
Kick *** oil.
Its actually thicker than Mobil 1 20-50 at 40 deg C, and it is the thickest oil I can find at 100 deg C.
Old May 21, 2011 | 03:58 PM
RockerMike's Avatar
RockerMike
Originally Posted by Thet
Can I buy Redline 20w60 at any generic local auto store? Or will I have to special order it?
I order my Red Line from Jegs. I use the 20/50 but here's the link for 20/60
http://www.jegs.com/i/Red+Line+Oil/816/12604/10002/-1
Very quick shipping and a free hat and stickers.
Old May 21, 2011 | 04:30 PM
txfxstrider's Avatar
txfxstrider
You will have no problem running 20w50. An oil cooler might give you peace of mind.
Old May 22, 2011 | 07:46 AM
jimmyp1's Avatar
jimmyp1
you can buy the redline oil @ cyclegear..sunset/pecos..they have another one on decatur..
Old May 22, 2011 | 02:40 PM
Thet's Avatar
Thet
Ended up picking up some 20w50 Valvoline. Read some good stuff about it and got it for $3/qt.
Old May 22, 2011 | 07:06 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
Im using Amsoil Synthetic 60wt Motorcycle oil in my trike with 117" engine. I see a 10 degree reduction in the oil temps during the summer. I do use a oil cooler as well.
Old May 22, 2011 | 07:43 PM
lionsm13's Avatar
lionsm13
Just an FYI in case you didn't know, Amsoil makes a fully
synthetic straight 60 weight oil that you may want to consider..
Old May 22, 2011 | 08:13 PM
Lost1's Avatar
Lost1
If it's VR1 you're set. Good, stout oil at a non-stout price.
Old May 22, 2011 | 08:24 PM
BLKBAGGER's Avatar
BLKBAGGER
The Redline 20/60 is perfect for hot areas. I have ridden my bike from San Diego to Vegas in the hot weather running it with great results. It's great oil.
Old May 22, 2011 | 08:36 PM
NoCoLoco's Avatar
NoCoLoco
20/50 is a good all around oil for most places but in colder climates you might wanna use 10/40 during the winter (if you're not snowed in) and in warmer climates you should probably use straight 50 or 60 weight during the summer.
