CB Connectors
Old May 23, 2011 | 08:36 PM
tommyj's Avatar
tommyj
Default CB Connectors
I've got the detachable tour pac on my 2008 Ultra and it has the Harley AM/FM relocated antenna mount. I want to hookup the CB the same way when I remove the pac. My question is: will I have to have a coil like the one in the tour pac or will a loaded CB antenna do the same job. Also, where can I buy the small connectors that look like a 259 but smaller? Thanks.
Old May 23, 2011 | 09:04 PM
Neil's Avatar
Neil
I suppose you could but the loaded base that was part of the kit for Street/Road Glides without Tour Paks. I'm not sure on that part of your question. For the other part you can do like I did when I made my 02 Tour Pak removable. I raided the parts from the 09 and up kit and got the patch cable for the CB. I used the frame mounts for the Street/Road Glides to mount both antennas. It makes the setup similar to the 09 and up setup. If you check my profile you can find some pics I attached to a post showing what I did. I don't have a need for the CB when the pak is removed. Only when I am on a road trip and I want to check traffic info via truckers. Good luck.
Neil
RDMC
PSRumors
2014-2024 Touring Models
17
Jun 21, 2016 09:36 PM
chrskrngl
Jun 20, 2011 03:10 PM
rhinoevans
May 24, 2010 04:12 PM
Ghostrek
General Topics/Tech Tips
Feb 28, 2009 07:20 PM
ftlee20723
Aug 18, 2007 04:02 PM
