decel popping after adding slip ons?
Old May 25, 2011 | 02:20 PM
Geoff's Avatar
Geoff
The decel pop was likely there before you added slip-ons. You just didn't notice it with stock pipes. As suggested above, make sure the headpipe flanges and pipe joints are secure.
Old May 25, 2011 | 03:39 PM
outgood's Avatar
outgood
I've enjoyed it since the 70's & 80's running shovels with drag pipes.
My a/f is tuned great, but still gonna pop.
Air-fuel ratio (AFR) is the mass ratio of air to fuel present during combustion. If exactly enough air is provided to completely burn all of the fuel, the ratio is known as the stoichiometric mixture.
Old May 26, 2011 | 08:06 AM
ecaldwell78's Avatar
ecaldwell78
Thanks for the responses guys! This is why I love this place! I have some time to kill this weekend so I think I'll take the entire exhaust system off and just replace every gasket and clamp. Thanks for the RTV tip too. I'll use that to make certain this system is as leak proof as it can be and check back in with my findings.
Old May 26, 2011 | 08:30 AM
FDHOG's Avatar
FDHOG
I had some popping even after a tune. When I checked my exhaust clamps (dealer installed), they were too far back, and only torqued to about 30ft lbs.
Tightened those babies up to spec, and the popping went away.
Old May 26, 2011 | 09:40 AM
Port Dawg's Avatar
Port Dawg
I have some popping and gurgling with everything on my King stock! It is in for the 1K checkup right now and I told them about it...looked at me with a crooked eye a bit like they couldn't believe it.
spf62
2014-2024 Touring Models
Apr 14, 2014 06:30 AM
steve48
Exhaust System Topics
May 18, 2012 07:19 AM
Steel Steed
Jun 24, 2011 08:53 PM
flhtupser
Mar 24, 2008 09:20 PM
snooper0069
Sep 21, 2007 01:44 PM
