Acc is dead
Old May 25, 2011 | 08:35 AM
mr2fast4u's Avatar
mr2fast4u
Default Acc is dead
Looking for some help or ideas
This past weekend i noticed that the acc switch light was not lit then I discovered that the cigarette lighter did not work.
Checked the acc fuse and it looks fine, any ideas?
2011 Limited, yes it is under warranty, but dealer is a hassle and has left a little to be desired. (loose battery trays, exhaust bracket falling off, scratched radio face, probably behind this too - maybe a loose conection...
Old May 25, 2011 | 08:47 AM
Zimbob's Avatar
Zimbob
How did you check the fuse? I had a similar problem with my '07 RKC, the fuse looked good till I used a test light on it, replaced the fuse and all was good.
Old May 25, 2011 | 08:54 AM
teedubya's Avatar
teedubya
The fuse which controls the accessory plug is not labeled clearly. It is in the same area but is not labeled as acc. Can't recall what is labeled as without going out to the shop and looking but check out some other fuses that are right there next to it.
mrjimbo's Avatar
mrjimbo
It's fuse #3, not fuse #2 labeled accessory. #3 is P & A, change it and you'll be fine....
Old May 25, 2011 | 11:30 AM
mr2fast4u's Avatar
mr2fast4u
Thanks guys Ill check it out
Old May 25, 2011 | 11:56 AM
Guy2008Ultra's Avatar
Guy2008Ultra
Be sure to let us know what you find.
Old May 25, 2011 | 11:59 AM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
if its not the fuse then check the connections or use a meter to see if you have a closed circuit.
I would take it to the dealer just to stick it too him. They need to fullfill their obligations to the customer.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Jswerve
Oct 8, 2018 08:06 AM
JoeCanz2
Sep 6, 2018 07:20 PM
PonyboyUSMV-MC
Oct 2, 2017 04:46 PM
strtglde11
Jun 4, 2013 10:42 PM
0204665J
Jul 23, 2007 04:28 PM
