Trouble Finding Neutral
Old May 26, 2011 | 03:22 PM
vet767's Avatar
vet767
Funny, but my rk is the easiest of three to find neutral don't remember not hitting neutral when I bumped it. Sporty was a bitch til I put the forwards on it now it's ok
Old May 26, 2011 | 03:27 PM
Punjabi Rider's Avatar
Punjabi Rider
Replace the stock shift linkage with heim joints linkage and see how better it gets.
Old May 26, 2011 | 03:38 PM
kevmiami's Avatar
kevmiami
Interesting - just replaced the stock ugly linkage with HD billet, which uses beautiful but dry ball joints. Have not had a chance to ride hardly since.
Old May 27, 2011 | 12:26 AM
bikehunter's Avatar
bikehunter
I found it got better when I changed the flimsy gear lever rod to a stiffer type
Old May 27, 2011 | 12:44 AM
Bigdad68's Avatar
Bigdad68
Throttle bump works. Went from my Indian Spirit to my 02 Ultra and wondered what was wrong, started bumping the throttle and she jumps right in smooth as silk.
Old May 27, 2011 | 03:54 AM
neous's Avatar
neous
1st Gear
Bookmarked
In my case experience is working out, I've had my 09 EGC for exactly 2 weeks, I put on 500 miles for a total of 3100, and up until yesterday finding Neutral was a crap shoot, but I'm developing a method with the toe lever which is to slowly raise the lever into N (can't use the heel without raising my leg so until it's adjusted i'm strictly "toeing" thru the gears.
Will have to try the "2nd to N" as well as the "RPM Bump" methods, because its
Old May 27, 2011 | 06:12 AM
leeinmemphis's Avatar
leeinmemphis
My bike got to the point it was hard finding neutral and we found it had a bad compensator in the primary.
Old May 27, 2011 | 07:30 AM
Wassup8687's Avatar
Wassup8687
Put some Redline in and you'll be amazed. I was having problems sometimes trying to find neutral and when I switched to Redline I couldn't believe the difference.
Old May 27, 2011 | 07:59 AM
robbie52's Avatar
robbie52
Gets better with time, but still a pain in the *** to find.
Old May 27, 2011 | 08:04 AM
kevmiami's Avatar
kevmiami
Recently installed new HD billet linkage which uses "huge" smooth joints at both ends and was heal tapping from 1st at full stop at lights; much easier - very cool Cheers, Kevin.
