Cvo amplifier....Biketronics Kit
Old May 27, 2011 | 07:41 PM
Dawolf's Avatar
Dawolf
6th Gear
Default Cvo amplifier....Biketronics Kit
I just installed a new radio after the hk bit the big one. I used a biketronics kit and tthey also gave me the pins to connect the rear speakers....everything was plugged back in and the new radio fires up....looks good....only problem is there is no sound. I checked with a speaker and there is sound coming direct from the radio, only it's not coming through the amplifier.....does anyone know if there is some kind of amplifier turn on lead for the stock amp?
It would seem to me that the amp would need some kind of remote wire to wake up when the radio turns on. The one for the turn on of the amplifier off of the stereo is not connected.
As it was I had to connect the wires directly into the big harness to hit the rear speakers. Has anyone ever run into this?
Old May 28, 2011 | 08:49 AM
DrPlastic's Avatar
DrPlastic
There was a single wire coming out of my BT module and yes it is an amp turn on wire. it is usually blue.
Old May 28, 2011 | 09:50 AM
Navy Mustang's Avatar
Navy Mustang
There should be a blue wire that turns the amp on. Connect this to your cig lighter hot post and you'll be in business.
Old May 28, 2011 | 10:06 AM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
HK amp is activated by CAN BUS, not a supply voltage. Without the HK radio, the amp will not turn on.
timber0472
Mar 1, 2015 09:46 AM
D RENEGADES
Audio Systems
Mar 29, 2014 05:11 PM
Fantozi
Audio Systems
Apr 26, 2013 02:56 PM
Rediron
Oct 29, 2010 03:12 PM
3itodd
Jan 5, 2009 10:11 PM
