Steering head asjustment
Old May 28, 2011 | 07:05 PM
c50plus's Avatar
c50plus
My steering on my uc 08 was not so good. Similar symptoms.
I changed the fork fluid in it feels like a new bike
Old May 29, 2011 | 01:34 AM
Potato_Potato's Avatar
Potato_Potato
Originally Posted by Neil
I've been told two different things about how to perform the test. Do you need to remove all the cables etc... to get a true reading? It would seemthat the clutch, throtle, brake lines etc... would create interference and corrupt the test. Any thoughts?
Neil
RDMC
This is from the '08 Touring SM
4. If the clutch cable or main harness appears to be influencing swing momentum, proceed as follows:
a. Clutch cable: Disconnect clutch cable at hand lever. Release cable from P-clamp fastened to upper fork bracket (FLHR/C), remove from inner fairing (FLHT/C/U), or release from cable clip on instrument nacelle (FLTR). See 2.23 CLUTCH CABLE if necessary.
b. Main harness: Remove screw and P-clamp to release main harness from right side of steering head.
c. Repeat previous step.
Old May 29, 2011 | 01:58 AM
2%er OG's Avatar
2%er OG
my 07 ultra fails the test do I have to remove the inner fairing or can the neck bearings be reached by removing the outer fairing two tighten them?
Old May 29, 2011 | 10:09 AM
Punjabi Rider's Avatar
Punjabi Rider
Which fork fluid did you use cause I have done every thing except the fluid change since 23K miles and now it's at 59K.
Old May 29, 2011 | 07:12 PM
HOG_0308's Avatar
HOG_0308
my fork fluids were changed three miles ago when i did the chrome lowers.
Old Jun 11, 2011 | 07:59 AM
HOG_0308's Avatar
HOG_0308
i was going to tighten the front steering bearing today. can anyone advise on at 08 Ultra, do i only need to remove the ignition and the inner fairing lower cover to get at the steering head?
Old Jun 11, 2011 | 08:21 AM
HDV-GLIDE's Avatar
HDV-GLIDE
The neck tightening bolt I believe is under your radio, so you have to remove the outer fairing only.....If you have a long enough open end/box wrench to grab the nut and tighten it while swinging the front end, you should be good....If I'm wrong, I'm sure others will chime in...
Old Jun 11, 2011 | 08:24 AM
HOG_0308's Avatar
HOG_0308
Anyone have any pictures?
Dieselsoftail
Jul 4, 2019 05:06 PM
fullautomike
Apr 27, 2016 10:28 PM
tom lipke
Jan 6, 2012 09:59 PM
08FLHXRYDER
May 2, 2009 12:33 AM
Luxe
Feb 20, 2008 11:38 PM
