Vibration after engine mount change..help!
Old May 28, 2011 | 02:45 PM
flhtupser's Avatar
flhtupser
Default Vibration after engine mount change..help!
I just changed the front engine mount on my '06 Ultra. I've put over 40k miles on the bike so I know how it was before. After the change below 2000 rpms it vibrates way worse than before. Idle is about the same as before. The fairing brackets were broken and I repaired them. I went back with a 79-B mount which is what was taken out. I have spent hours moving the mount around trying to find a sweet spot but can't. Has anyone experienced this and found a fix? I just want my bike back like it was before. Please if anyone has a fix I would really appreciate it.
Old May 28, 2011 | 02:53 PM
BLKBAGGER's Avatar
BLKBAGGER
I have had the problem many times in the past and don't have an answer for you. I do know that it takes many miles before the new mount will start to settle down and soften up. I just live with it and after a while forget about it. It's about that time that the mount is ready for replacement.
Old May 28, 2011 | 06:44 PM
whoop72's Avatar
whoop72
if you can't find a solution with your mount, you might try a glide-pro. works great on my 07 rg.
Old May 28, 2011 | 08:27 PM
Lost1's Avatar
Lost1
+1 for Glide Pro.
Old May 28, 2011 | 08:30 PM
TORQUEY's Avatar
TORQUEY
Just a guess here, so forgive me...would changing only ONE motor mount screw things up as the other rubber mounted areas are worn to a degree and one is brand new? Would this cause a sympathetic vibration?
Old May 28, 2011 | 09:41 PM
fabrik8r's Avatar
fabrik8r
You went from a worn motor mount, possibly the cast in metal sleeve was broken loose from the rubber, to a new firm mount. It should be expected that more vibration will be transfered to the chassis with a stiffer mount, and that is the typical result. Try the Glide-Pro or Sta-Bo motor mount, both of a similar design with a floating metal sleeve, kinda like a broken mount.
Old May 28, 2011 | 10:16 PM
shaker's Avatar
shaker
I am experiencing the same vibration and I just installed a Glide Pro. I have a 2007 Street Glide and remember it not being this bad. The original mount was split and the sleeve had broken loose from the mount. Anytime I get around 2000 rpm's the mirrors vibrate beyond being able to see. I have also installed new brackets in the fairing that were broken. It can be very annoying but anything above 2000 rpm's and the mirrors smooth right out. Hate to think I will have to live with it but if so I will.
Old May 28, 2011 | 10:25 PM
BackRoader's Avatar
BackRoader
One day while changing oil I noticed my front mount bolt on left side was missing. On closer inspection I saw no wear from bolt on the block, etc and realized that it had come from the factory missing a bolt. Went to HD, bought and installed both bolts and rubber bushings. Instantly noticed more vibration. I assume that since it had been loose on one side, the engine was free to move more and vibrate the frame less. JMO.
Old May 28, 2011 | 10:29 PM
Stiggy's Avatar
Stiggy
Just put the 79 B in mine last month and Man(!) the vibration shortened my trip that day. After a thousand miles it's settled down significantly.
By the way, 2000 rpm is one good way to break your crank, ( scissor.) The ISO system was never designed to smooth out the vibes at 2000 rpm. I ALWAYS keep them at 2200 and above. Mine turns 90,000 miles this week
Old May 29, 2011 | 10:14 AM
Punjabi Rider's Avatar
Punjabi Rider
New HD mounts are harder and suppose last longer but not without the discomfort of vibrations.
