Bought some Sumax bag liners earlier this year & finally got around to installing. Wanted to spruce up the insides and thought these would do the trick. Now...I'm NOT an expert w/upolstery so getting these properly in-position & glued definitely wasn't my best work. Overall they are a good product, but (as w/all instructions) looked easier than instructions indicate(d). Here's my take:
1. Are they a good product = yes
2. Do they look good = yes
3. Are they easy to install = no
4. Would you recommend = maybe
One of the problems are the rubber grommets (remove/replace). Instructions say to remove, position liner & replace grommet. Unless I'm missing something - this is "impossible" because just getting the grommet back into the little hole was a feat in iteslf. My wife made the mistake of checking on me after about ~20 minuted of "grommet wrestling" and she understood & backed away. Also, smoothing the liners in-place before glue cures...let's just say - leave it to the pro's.
I plan to get extended bags someday so not worried about the results, but IMO - spend your $$$ on other upgrades. Enjoy!
I got the HD ones. They are a little bulkier, but you can pull them in and out in a couple seconds. Watch your weather today there in Omaha ice. It ain't lookin' good.
I just covered the grommets with the material and used a razor blade to cut around the grommet when I was done. The first liner was a bitch but after seeing my mistakes, the second one wasn't to bad. With the lids closed, no ones going to see your imperfections...
I installed the HD liners on my '06 Road Glide,exspensive but the fit was perfect.
Now on my '11 Limited I installed the Custom Chrome liners.Took a little work to get them in there.Cant complain for the $62 price tag.
These are only held on with velcro at the top.
