Front Brake question
Old May 31, 2011 | 06:42 AM
Route66rider's Avatar
Route66rider
Default Front Brake question
My '05 Ultra Classic has developed an odd problem with the front brake lever after sitting overnight. When I first get on the bike the brake lever can be be pulled back all the way back where it touches the grip. I checked the fluid level and it is OK. It does not change if I try to 'pump' the lever multiple times, However, if I just ride for about three or four minutes and then try it again, the travel is OK going to the middle of the range.
The brake pad material appears to be about the thickess of the backing plate, say around 1/8 inch or .125.
Has anyone seen this sort of issue before? I was wondering if it could it be the front brake master cylinder? Caliper?
Old May 31, 2011 | 06:51 AM
JayStronghawk's Avatar
JayStronghawk
I would pull the Calipers and clean the pistons and if the Pads are even close to looking like changing do them as well while got them tore down ...
Old May 31, 2011 | 06:55 AM
nvsteve's Avatar
nvsteve
Ditto on the above and try bleeding the lines.
Old May 31, 2011 | 07:03 AM
SpiderPig's Avatar
SpiderPig
I agree with all the above with the addition of flushing the fluid with getting some new fluid in there may give better results. Being an 05 if you haven't flushed with new you are overdue.
skos
Mar 28, 2020 09:58 PM
larry harding
Jul 6, 2016 07:47 AM
Hackd
EVO
33
Apr 16, 2015 01:59 PM
mikebehr00
Wheels/Tires
Feb 23, 2014 11:16 AM
WVHogRider
Mar 27, 2012 08:05 AM
