volt meter jumping
Old Jul 28, 2011 | 07:39 PM
SC_Compact's Avatar
SC_Compact
Originally Posted by TheProfessorVMC
It is bouncing hard and fast. It starts normal, climbs normal, however when I get to cruising speed and only after about 20 miles does it start to bounce. It will bounce from anywhere between 13 to a little above 14. It does it quickly and hard. It will do it at all RPM (once down the road 20 miles or so) until I come to idle speed. Then it will not do it again until I am cruising at 70 mph or better.
Mid May I left NY for Arkansas. By the end of the second day I noticed my voltmeter bouncing around just as you describe. When I pulled over for gas meter went back to 14. Once back on the highway the meter started jumpimg around again. When I got to Arkansas I had the electrical system checked by an indi and he said it wasw fine.
I've pretty much decided to just live with it the way it is.
Another shining example of HD quality. I wonder if the guage was made in China.
Old Aug 3, 2011 | 07:55 PM
TheProfessorVMC's Avatar
TheProfessorVMC
3rd Gear
Update... problem fixed. New Voltage Gauge. $54 from the local Harley dealer. I looked at the connection on the old one and it looks like the positive connection had a small amount of corrosive dust on it. I believe it is made out of aluminum it was a white'ish discoloration... could not clean it off. Not sure if this was the issue but the new one both contact are shiney. Anyhow... was lucky this time.
Old Aug 3, 2011 | 08:05 PM
69cj's Avatar
69cj
Originally Posted by Akitakoi
It should be at 14 at idle and increase about 1 volt for every 1,000 rpm. Is that what you mean about jumping or is it just bouncing around at a constant RPM?
Mine may have done this before the stator went out but I rarely look at it.
With that logic you will fry a battery in no time. they won't take 16 to 18 volts for very long. Look at what you said or do the math.
Old Aug 3, 2011 | 10:39 PM
mike08sg's Avatar
mike08sg
mine was a loose positive battery cable,hasn't done it since
Old Aug 31, 2011 | 08:10 AM
TheProfessorVMC
3rd Gear
Default Update
OK folks... new voltage guage... seemed to fix the issue... after another 200 miles the guage started bouncing again. Decided, screw it and bought a new battery... this did not fix the problem. The voltage guage is still bouncing after about 20 miles down the road when the engine get good and warm. Back to the drawing board for me. So far, New Voltage regulator, New battery, New voltage guage, all that is left is the stator. Taking this pig into the Harley dealer and have them do a full check on the stator... Something is just not right... I have even replaced all the relays on the fuse box... the bike runs fine... but this is just something that is blowing my mind.
Old Aug 31, 2011 | 09:00 AM
dbell66253's Avatar
dbell66253
My bike is in the shop right now for a charging issue, bike is fine until it warms up, voltage drops then engine and battery light come on, just had stator and battery replaced about 1100 miles ago, I told the dealer then they might as well replace the regulator also, no deal. Yesterday they called me and said the regulator is shot, lol. I'm glad it's all under warranty, I told them yesterday I believe it's the regulator that probably took the stator out the first time and they might want to replace or at least physically check the stator again to make sure it's ok, no deal, I won't be surprised if it's back in the shop again soon. As long as it's under warranty and they don't want to listen, I don't care, once the warranty runs out I won't be taking it back and any fix I need I'll do it and get it right the first time.
Old Aug 31, 2011 | 09:12 AM
NewAge's Avatar
NewAge
Professor, I'm pretty positive it has got to be the stator. A quick trick to tell if it is the gauge or the stator is to turn the bike off and tap on the face of the gauge. If the pin moves, its a bad gauge - if not, its the stator. Had the same issue with my 10 SG. Did the tap and it bounced, replaced the gauge (under warranty) and never another issue. That was at about 12K - still fine now at 28K. Good luck!
Old Aug 31, 2011 | 09:16 AM
Uncle Larry's Avatar
Uncle Larry
13.5 to 14.2 is optimal voltage .... anything below 13.5 indicates low output, and anything over 14.2 indicates overcharging. Of course low output leads to a discharged battery, while high output will eventually cook the battery. Overharging will cook the water in the battery and most batterys are sealed today so there is no way to add water. While an increase in the rpm's will generally increase voltage output minimally ( usually not much more than one and a half volts ) it is incorrect that the voltage will increase one volt for every 1,000 increase in rpm's. If that were the case you would be charging at a rate of approximately 17 volts at 80 miles per hour ( 2,900 rpm's on my scooter ). Some times erratic voltage can be attributed to a suspect battery. Be sure that all your connections ( especially grounds ) are clean and tight. Check your battery with a load tester ( this is the best way to effectively and accurately determine the condition of your battery ). Many times I have seen a volt gauge have readings different from what the load tester indicates. While my response may not address the OP's question directly I tought I'd address the response given by Akitakoi and try to clarify things. Hope this helps.
Old Jun 12, 2012 | 02:37 PM
johnpaul's Avatar
johnpaul
Stage IV
Update... Tested battery at speed - No issues. Tested Stator connections - No issues. Disconnected Voltmeter gauge and attached my shop voltmeter and went for a ride... No issues with charging... summation is that replacement of voltmeter gauge $84.00. Will replace voltmeter.
I am very interested in what fixed your problem. I have the exact same issue, sounded like you were riding my bike (2009 FLHTCU). I replaced the battery just because it is three years old, checked all grounds, wiring, and connections, all was good. I felt like the regulator was breaking down after it warmed up, but that didn't help. My shop voltmeter shows the charging system to be working right in all areas. I have ordered a volt meter to see if that will fix the problem. Please reply with a fix.
Old Jun 26, 2012 | 07:55 PM
johnpaul's Avatar
johnpaul
Stage IV
Originally Posted by big ears
Mine did it at 19000 miles. Only when warm and going 70 or so. Dealer changed out the meter. Works fine now.
My 09 ultra is doing the same thing. Has the new meter fixed your problem?
