Dyna Bead ??
Old Jun 6, 2011 | 12:23 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Dynabeads = snakeoil
And some of you use car tires. And some use less than the recommended high-grade fuel. And some use auto oil. Don't stay stuck on stupid. Get the facts before you line up behind the forum pied pipers.
petemac's Avatar
petemac
I'm putting a new rear tire on this week and going with the dyna beads.
Old Jun 6, 2011 | 12:25 PM
firefightermike's Avatar
firefightermike
Originally Posted by DPete
Been reading alot about them on the posts where tire weights fell off. My question is do they last the life of the tire? Seems like they would wear out rubbing against each other inside the tire during acceleration / deceleration
I used them on my last bike. I think they do as advertised. I will use them when I do my first tire change.
Old Jun 6, 2011 | 12:33 PM
jjnoble's Avatar
jjnoble
Originally Posted by jackhis
Here is my 2 cents!
The principle is all tires are spinning on ball bearings, and nothing will roll smoother than a bearing at any speed.
A balanced tire with dead weight will match the tire rotation with the bearing at ANY speed. The Dyna beads, or other beads will NOT balance the tire at certain speed, especially at low speed, and it requires AN AMOUNT OF TIME for the beads to distribute, or concentrate at a "right location" to balance the rotation.
You can see in the "demo".
A weight will NOT come off the rim, if there is a proper preparation the bonding surfaces.
Here is an article from the company in the above post, which has confirmed my theory: beads cannot comparing to the traditional balance method.
http://www.innovativebalancing.com/LowProfileTires.pdf
Use whatever method that make you feel good, but to be real. You know what to use!
Sounds like a standard disclaimer to cover their butts just in case. Many companies do that, just in case so you can't sue them IF anything questionalbe where to happen. Does not mean they don't work and work well.
Also, how much balancing does a tire need at slow speed? If you are creeping through a parking lot does it really matter, at all? That is a question, not a statement. I'm not an expert but it seems like the faster the rotation the more balancing required, conversely, the slower the rotation the less balancing required. So the beads adjust accordingly with the speed of the rotation. I wondered about that before I put them in, still wondering. Anyone have an answer?
Old Jun 6, 2011 | 12:45 PM
tombeving's Avatar
tombeving
I use them on my Duece and am happy with the way they work. I bought a 2011 Ultra SE and the weights fell off the front wheel and damaged the front fender. Harley replaced the fender free, but I will be using dyna beads as soon as I get the bike back.
Old Jun 6, 2011 | 03:00 PM
carlgrover's Avatar
carlgrover
How much balancing does a tire need at slow speed? About as much balancing as your lawn tractor tires. Unless of course, you're NSCoyote and are planning on powering your tractor with a shovelhead motor so you can mow at 90 mph.
Dyna beads are a wonderful thing.
Installation tech tip: When the fill tube is stuck full of beads and they aren't running into the tire, give the bottle a quick squeeze (like you would your wife's boobies) then let go a few times in rapid succession. The pressure/suction from the bottle will make the beads jump and will alleviate the traffic jam thus causing them to flow into the tire easier.
Old Jun 6, 2011 | 10:50 PM
jrplane's Avatar
jrplane
Default Beads
I put the beads in a perfectly balanced tire, They made no change. So I removed the 1 oz. weight from that perfectly balanced tire and it still rode great. I have done this to my bike and the wifes. If the beads can take place of the weights with no ill effect they are a winner in my book. I have used the same beads over and over.
For all who say they don't work, try them, they are cheap, if you dont like them, dump them out and have tire balanced!!!!!!!!!!!
Sunnyday91360
2014-2024 Touring Models
May 22, 2020 12:41 PM
skypilot_one
Oct 1, 2014 12:13 PM
parrettdl
Jul 1, 2013 08:51 AM
Scudda
Jan 19, 2013 05:29 AM
HDF Tech
Jun 25, 2005 01:29 AM
