Touring ABS single sided rotor review
Old Jun 8, 2011 | 12:20 PM
VETERAN75's Avatar
VETERAN75
Default Touring ABS single sided rotor review
I did it so this is first hand opinion.
Went to custom wheel with single sided rotor and have ABS.
As I expected I lost some braking power but I don't ride loaded down to the gills. Using both the front and rear I can still stop on a dime.
I have the 11.8 rotor(the 13 may give you a little more braking but not much). 6 piston caliper. You factory master cylinder will work as long as it's 2008 or newer which is when they changed them I think. You have to change the brake line from the module to the caliper to a single line. You have to get the ABS module bled and recalibrated. Should take dealer about 2 hrs, mine did.
I know they're some people that will scream safety. Fact is the bike still stops and I 'm happy, I pay my bills and live my life, NOT you safety sam.
Good day.
Attached Thumbnails Touring ABS single sided rotor review-100_0857.jpg   Touring ABS single sided rotor review-100_0856.jpg   Touring ABS single sided rotor review-100_0863.jpg
Old Jun 8, 2011 | 01:24 PM
KCFLHRC's Avatar
KCFLHRC
Wow, kinda defensive right off the bat aren't we? I think it looks good. Now if you removed the other rotor it would really show off that wheel. No safety comments from me, do what you want.
Old Jun 8, 2011 | 02:21 PM
slothy's Avatar
slothy
well i can add that with a 26" front wheel and 13" rotor/6 piston caliper, its stops great and the abs works. tested it last week to see if it would work or not with single rotor/large wheel.
Old Jun 8, 2011 | 02:51 PM
monkey sammich's Avatar
monkey sammich
Looks good. I don't know what size the tire is, but I'm not impressed with the current big wheel fad. Yours shows a thicker tire, which I think looks much better.
Old Jun 8, 2011 | 03:12 PM
o-matt's Avatar
o-matt
Dang. I almost went with this setup (albeit a 13" rotor instead of the standard 11.8") and decided to keep the duals. Ah well. Maybe someday.
Anyways, your bike looks hot!
Old Jun 9, 2011 | 12:29 AM
qtrracer's Avatar
qtrracer
My 08 FLHX has the dual brembos and I rode a guys 09 FLHX with a 21 front wheel and a 13" single w/PM 6 piston, I thought it sucked *** for stopping power in comparison to the stock dual brembo set up with the stock front wheel. Looked great though.
Old Jun 9, 2011 | 02:32 AM
Twinrider's Avatar
Twinrider
The right side of the wheel looks fantastic without the rotor. Shame about the left side...
Old Jun 9, 2011 | 02:35 AM
103 sedona orange's Avatar
103 sedona orange
YES, + what KCFLHTC said !!!!!
Old Jun 9, 2011 | 02:52 AM
Hydroboy35th's Avatar
Hydroboy35th
Its called the 360brake, if you wanna drop a $1K for a brake setup
Old Jun 9, 2011 | 05:13 AM
kingkingking's Avatar
kingkingking
umm, twin discs are not installed for more braking force, that can easily be achieved with more pistons in the caliper or a smaller master cyl.
Twin discs are installed for more braking capacity ie resistance to overheating and fade.
A single disc can easily provide enough force to lock the wheel, but on a long downhill mountain pass a single disc can overheat, fade and result in a loss of brakes. Especially if you are riding hard. If you are a cruiser then you probably wont notice the difference.
