My hog is sick.
Old Jun 9, 2011 | 04:25 PM
big ears's Avatar
big ears
Default My hog is sick.
Had to bring my pig in to the dealer this morning. Been making grinding noises in the primary area. When I went to back out of my garage the old gal started without hitting the start button. It did this several times. My radio also went backwards. The display was totally backwards. It worked but I couldn't read it without a mirror. Service writer said thats spooky. I think the starter may be engaging while the motor is running. Who knows? Let the experts figure it out. Warranty is out next month.
Old Jun 9, 2011 | 04:48 PM
Glidedsternfan's Avatar
Glidedsternfan
Default Backwards radio?
Was the music coming out backwards too?!?!?!
Did you hear, "Paul is dead"?
That is kinda freaky.
Old Jun 9, 2011 | 05:30 PM
Lost1's Avatar
Lost1
My starter did the same thing about 2 years ago- would engage while running & would start itself when the ignition was turned on. Starter switch was bad so dealer replaced the RH handlebar controls under warranty.
Old Jun 9, 2011 | 06:17 PM
18BKLR's Avatar
18BKLR
Weird?????????????
That some children of the corn **** !!
Old Jun 9, 2011 | 06:47 PM
1HarleyGuy1's Avatar
1HarleyGuy1
You don't by any chance call your bike "Cujo" do you???
Good luck with it.
1HarleyGuy1
Old Jun 9, 2011 | 07:48 PM
69cj's Avatar
69cj
Mine did that and when I let out the clutch the primary started screaming. Thought the clutch adj. nut had come loose. It was the return spring on the start switch that failed. The starter was not retracting.
Old Jun 10, 2011 | 09:58 AM
big ears's Avatar
big ears
The radio play ok, just the display was backwards.
Old Jun 10, 2011 | 10:49 AM
classic53's Avatar
classic53
Were you in an episode of the "X-files?
Old Jun 10, 2011 | 11:59 AM
carpetride's Avatar
carpetride
You don't need a dealer.
You need an exorcist.
Old Jun 10, 2011 | 01:52 PM
rdb1976's Avatar
rdb1976
Did you maybe get on from the wrong side?
