How bad am I screwed?
Old Jun 13, 2011 | 11:33 AM
im's Avatar
im
Please double check. I could be wrong but the tank fittings are not 3/4" they are 18mm x 1.50.
Consider avoiding helicoil since you could introduce leaks.
Spark plug thread chaser with some lube is rather inexpensive and my resolve your problem..At least it did for another forum member.
Old Mar 27, 2013 | 08:44 AM
Scary Gary's Avatar
Scary Gary
6th Gear
I am going through this exact same f6king thing. The threads are indeed 18mm x 1.50...How "convieniant" NOT. Plus, the dang Goodrige fuel lines I bought are so darn short they dont want to line up right and cause this problem. I am going to try chasing the threads. What a cluster f66k.
Old Aug 17, 2015 | 06:25 PM
ntfreel53's Avatar
ntfreel53
Thanks thread chaser seems to be ticket
Old Aug 17, 2015 | 06:39 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I'd put some grease on the thread chaser to help trap any metal pieces coming off the damaged threads.
Can't believe I just responded to a two year old thread, must have been along day at work!
Old Aug 17, 2015 | 08:06 PM
Dr. Tiki's Avatar
Dr. Tiki
Originally Posted by Reaper22
Is it bad enough you cannot chase the thread with a tap? then use teflon tape..
Purchase a Thread Restorer kit. Never use a tap for that job. A tap will just cut new threads, you don't want that.
Old Aug 17, 2015 | 08:12 PM
Twincruiser's Avatar
Twincruiser
Maybe you are trying to thread in 3/4x16 threaded lines into a metric 18mm threaded fitting on the tank? That would cross thread one of them every time.
***crap, I just responded also to a two year old thread*** Time to close it out.
t059736
Jan 6, 2019 03:32 AM
KrustyHD222
Apr 7, 2013 09:14 PM
rickthestick
Dec 7, 2011 01:08 PM
SpyderTB
Exhaust System Topics
Oct 27, 2009 09:18 AM
rustyed
Jan 6, 2007 12:43 PM
