Dragonfly Mounting Question
Old Jun 14, 2011 | 01:39 PM
sgnden's Avatar
sgnden
Default Dragonfly Mounting Question
OK - Almost ready for paint on my Dragonfly project (it was 50% destroyed and now glassed and just needs some fine-tune shaping.
I need some advice on what type of sleeve or grommet I should use on the mounting stud since the Dragonfly mount's slots are much narrower than the setup on the windshield mounts (where the stock windshield mounting grommet would normally go).
Make sense?
Thanks!
Old Jun 14, 2011 | 02:09 PM
07RoadHawg's Avatar
07RoadHawg
The top ones are removed and you just tighten down the bracket and sandwich it all together. That way a thief at least needs a 1/2" wrench to get it off and run with it.
The lower ones stay in place.
Old Jun 14, 2011 | 02:16 PM
Mike's Avatar
Mike
Sandwich the upper mounting bracket in between a couple of flat washers, then tighten it down.
Old Jun 14, 2011 | 02:25 PM
Mike's Avatar
Mike
Did I email you the Dragonfly instructions for the fairings? I seem to remember that I might have.
Let me know if you need them re-sent.
Old Jun 14, 2011 | 02:38 PM
sgnden's Avatar
sgnden
Hmm...I will check. Probably. I swear, these damn "Junior senior moments" are becoming waaay too frequent!
Old Jun 14, 2011 | 03:17 PM
Mike's Avatar
Mike
check your email. Just sent the two documents again.....
Huckster
Nov 4, 2017 03:38 PM
got2ride
General Topics/Tech Tips
Apr 3, 2017 07:32 AM
Briboysr
Jul 30, 2013 06:13 PM
Johnny_Ringo
Dyna Parts
Nov 22, 2009 01:53 PM
anubisss
Apr 6, 2008 11:00 PM
