Improving CB Reception?
Old Jun 17, 2011 | 11:14 AM
ZUTEDUFF's Avatar
ZUTEDUFF
i believe the correct why to check the swr is to remove the outer faring and attach the meter directly to the CB and antenna; not in the tour pack... the connections from the radio to the start of the antenna cable should be the usual CB connections
Old Jun 17, 2011 | 12:55 PM
98Ultra's Avatar
98Ultra
That would be the best way because you would be checking the cable also. It works in the tour pak though.
I used an antenna analizer and meter, both in the tour pak. It was easier that way.
Old Jun 17, 2011 | 03:08 PM
larsfum's Avatar
larsfum
Yesm, the correct way is to plug the SWR meter in line
Radio>SWR Meter>Antenna
Old Jun 17, 2011 | 11:48 PM
dnitram's Avatar
dnitram
Ditto on the ground, but maybe it's a lame question, but do you have the RIGHT antenna in place (not switched)?
Old Jun 18, 2011 | 08:37 AM
bobros's Avatar
bobros
Good question. How do you tell the difference on the newer antennas?
Old Jun 18, 2011 | 01:58 PM
Krow's Avatar
Krow
Both of the stock antennas look the same but apparently internally they are different. If you look closely at the plastic mount at the bottom you will see CB on one and AM/FM on the other. From what I've read on these forums, mixing them up can damage the CB.
Old Jun 21, 2011 | 09:55 PM
motorcyclecommunications's Avatar
Former Sponsor
If you need help troubleshooting your system or simply increasing your distance click this link and check out the info.
http://www.motorcycle-communications.com/Sun.html
Talldog
Jun 22, 2022 06:12 AM
Long lonesome highwayman
Nov 2, 2018 07:19 PM
FurryOne
Milwaukee Eight (M8)
15
Oct 1, 2017 10:34 PM
Hickey33
Feb 21, 2017 05:04 PM
sgl0226
Nov 22, 2013 05:35 PM
