I'm considering a 2009 EGC with 1877 miles. It has Vance & Hines Tapered Slash-Cut Slip-ons, Vance & Hines FuelPak and Vance & Hines VO2 Air Filter kit with Drak cover.
I know that V&H makes fine pipes, but I don't recognize their fuel injection systems and air kits.
Is anybody running this setup? How do you like it?
Thanks.
Monster Oval slip-ons, Drake filter, Fuel Pak and Throttle Pak....No issues in over 8000 miles....Knock on Wood!!!!!
Did HD have to do anything involving modules other than those in your kit?
Throttle Pak gets rid of the throttle lag that the throttle by-wire bikes have. Yes, it's noticeable when you twist the throttle fast while riding. The bikes speed picks up faster because the butterfly in the injector port opens faster then stock. Check on the V&H site for a video which explains it better. No adjustment by HD needed for what I have and for what you want.
