Dimmer switch splice.
Old Jun 22, 2011 | 06:18 PM
pons's Avatar
pons
4th Gear
Default Dimmer switch splice.
I have three questions about headlights and aux. lamp on the Ultra Classic. I have a '06.
1) I want to run both the headlight and aux lamps at same time on high beam. How's that done?
2) I found this switch splice on internet that allows you to run the high and low beam at the same time on headlight. Anyone done this?
3) Does the splice in questions allow you to run the aux and head lamps together?
Old Jun 22, 2011 | 07:03 PM
stafford's Avatar
stafford
In your headlight bucket there is a red wire with an orange strip on it. find it and run a jumper from it to the yellow wire on your headlight plug.
Old Jun 22, 2011 | 07:16 PM
JGroves's Avatar
JGroves
It allow you to run your low beam and high beam together. Your ax lites work too. I did it to mine 4 years ago.
Fuerte
Apr 23, 2018 12:54 PM
Dale_K
Electrical/Lighting/Alarm
Mar 5, 2016 07:42 PM
rags
Sep 29, 2015 05:17 PM
Vinish
Apr 9, 2012 03:03 PM
Bigstick
Sep 7, 2011 04:51 PM
