Flat Tire Repair??
Old Oct 18, 2017 | 04:43 PM
  #31
Musician's Avatar
Musician
Default flat tire blues
I've used a plug kit that uses mushroom shaped plugs. Comes with all the tools needed for installation. Glue not needed, air pressure, and the shape hold it in place. Installed correctly, never had a problem, and wore the tire out. never lost any air, and I checked it frequently to be safe. Worked well, no matter the load, or any possible abuse from going a bit fast. I also now use a sealant that is way friendlier to use than slime, and it helps balance , as well. Can't see tossing an almost new, expensive tire because somebody's a worrywart, or just wants that sale. Just be careful, and do a GOOD job the first time.
Old Oct 18, 2017 | 09:17 PM
  #32
teeroy_'s Avatar
teeroy_
I've had good luck with plug kits on everything from atv's to truck tires.
just an FYI to anyone considering the little CO2 canisters for filling, get the filler adapter with a valve to release the contents, and do not hold on to the canister with a bare hand while discharging. it will freeze to your skin. you'll need at least 5 of them to fill a tire to 35-40 psi.
Old Oct 19, 2017 | 06:51 AM
  #33
sumncguy's Avatar
sumncguy
http://www.twistedthrottle.com/stop-...CABEgKsfvD_BwE
craigcrewcheif
May 15, 2014 02:08 PM
bigredwing
Jun 9, 2010 02:52 AM
eleutheros
Nov 8, 2007 12:04 AM
dlongo8241
May 27, 2006 11:26 PM
RussDee
13
Apr 7, 2006 10:10 AM
