Rear brake is out
Old Jun 24, 2011 | 05:14 PM
bmcgc's Avatar
bmcgc
Default Rear brake is out
This is odd.
Just completed a 1500 mile trip on Tuesday, then a 150 mile trip on Wednesday. Bike ran great.
Went out today and no rear brakes at all.. Plenty of fluid, dont see anything wrong.
Any suggestions?
Old Jun 24, 2011 | 05:36 PM
smithbrl's Avatar
smithbrl
Do you have any resistance in the pedal when you push it or does it go straight down? How's your rear pads looking? Without knowing any facts, I'd guess master cylinder. Or maybe a problem with the linkage from the pedal to the m/c.
Old Jun 24, 2011 | 08:16 PM
dawg's Avatar
dawg
A lot of 09's are having problems with the rear brake switch. Check that and make sure yours is not compromised. Have you seen any fluid around/under the bike at all?
Old Jun 24, 2011 | 08:41 PM
themensh's Avatar
themensh
My '09 brake switch (rear) melted and fluid leaked. It was easy to find.
Old Jun 24, 2011 | 08:50 PM
wtb3886's Avatar
wtb3886
Default Same thing happened here just this week.
My 09 rear brake sensor disk ruptured is what I was told, my 1st indication was a smell then I needed my rear brake and she went to the floor.
Old Jun 24, 2011 | 08:57 PM
bmcgc's Avatar
bmcgc
No fluid leak that I can see.
No resistance on the pedal.
I think I hear air movement when I depress the pedal but Im not sure.
Old Jun 25, 2011 | 07:23 AM
KylePutzier's Avatar
KylePutzier
I just had to replace my rear brake line. The clutch cable (which had a wire coil around it) was rubbing against it and eventually wore through. I didn't see any brake fluid on the ground or anything else visibly wrong before dis-assembly.
The new brake line was of a different, more flexible design. Quite expensive also.
Kyle
Old Jun 25, 2011 | 08:50 AM
bmcgc's Avatar
bmcgc
So I went out this morning to work on the rear brake.
Sat on the bike and the brake works fine.
I must have a switch or sensor that is intermittant.
09 FLHT non-ABS.
Any ideas?
Old Jun 25, 2011 | 09:10 AM
98Ultra's Avatar
98Ultra
Kyle
Same thing happened last year on my 08 while on vacation in the mountains. NO fun with just front brakes on those roads.
Old Jun 25, 2011 | 04:42 PM
smithbrl's Avatar
smithbrl
When the brakes aren't working and you push the pedal, does the pedal feel the same as when the brakes are working or does it go all the way down to the floor? If the brake goes to the floor, can you pump the pedal a few times and get the brake to work?
