Tour Pak wiring
Old Jun 28, 2011 | 09:26 PM
groaning's Avatar
groaning
Default Tour Pak wiring
I'm thinking of mounting a led 3 wire running/brake light bar to my tour pak. Would splicing into the tour pak lights (the non led tour pak lights) work? If so, what are the 3 wires- red with yellow stripe, blue, black? One should be ground, one running, the other brake. The United Pacific led light bar has 3 wires, red, black white. Which goes where?
Old Jun 28, 2011 | 09:51 PM
All Aces's Avatar
All Aces
I just put the Air Wing led light in mine. It came with a "Y" to connect if you had lights in the TP. I have the EGC so I just plugged into the connector but if I had the ultra the directions said to use this Y splitter for the 3 wires. You just need the male connector end which is no big deal.
Old Jun 29, 2011 | 09:25 PM
groaning's Avatar
groaning
With my voltage tester I determined that:
red/yellow stripe wire is the brake light
blue wire is the running light
black wire is the ground
The United Pacific 12" led light bar (part #39607) with 3 wires:
red wire connects to the brake light wire
black wire connects to the running light wire
white wire is the ground
In the absence of a 3-way connector, splicing worked just fine.
VERY bright brake light with 14 high intensity leds mounted under the tour pak is subtle but effective.
Old Jun 29, 2011 | 11:39 PM
Harleypingman's Avatar
Harleypingman
Take a couple of pictures and/or a short video clip of what you installed; folks are always looking for tour pak lighting products.
Congrats on your installation.
Carl
Old Jun 30, 2011 | 01:13 PM
ThunderBueller's Avatar
ThunderBueller
Pics please!!!
Old Jun 30, 2011 | 06:22 PM
seph10's Avatar
seph10
Yes you can tap into your tour pak wiring, I did and it works great,,you can use a test light to figure out what wire does what if you need to,,,
Old Jun 30, 2011 | 06:48 PM
usmc3468's Avatar
usmc3468
Who said you needed us....................
markthardy
Feb 4, 2017 07:33 PM
nivensid
Feb 16, 2013 12:19 PM
rde
Nov 28, 2008 10:03 PM
TheShrink
Nov 24, 2008 06:37 PM
oley55
Feb 24, 2007 08:33 PM
