Tour Pak L.E.D. strip
Old Nov 23, 2008 | 08:16 PM
TheShrink's Avatar
TheShrink
Default Tour Pak L.E.D. strip
I just bought one of these to put across the back of the tour pak. Where are you guys getting the running light & brake light wires from? Thanks!
Old Nov 23, 2008 | 08:42 PM
Harleypingman's Avatar
Harleypingman
To install the HD Tour Pak Spoiler/LED, I simply spliced the wiring used for the Ultra light bar and side lights inside the tour pak.
If the LED can handle both the run and brake light functions, you can do the same; otherwise, pick whether you want the LED to function as a run or brake light and wire it accordingly.
Old Nov 23, 2008 | 09:29 PM
TheShrink's Avatar
TheShrink
Thanks! I have the Badlands Illuminator and I wanted to wire this strip up after the controller, therefore using the abillities of the controller for run & brake. I just can't find the right wire under the seat. I know which wire is "brake", but what color is "run ,(tail light)". Make sense?
Old Nov 23, 2008 | 11:03 PM
Harleypingman
More than likely, the "run" light is blue. Use a test light; the light should come "on" when the ignition is "on" and turn "off" when in the accessory position.
Old Nov 24, 2008 | 08:28 AM
TheShrink's Avatar
TheShrink
Thanks Bro, I appreciate the help.
Old Nov 24, 2008 | 10:56 AM
jerseyjeff62's Avatar
jerseyjeff62
Can you post a pic of the strip after you get it installed? i think there should be some sort of light higher for close traffic
Old Nov 24, 2008 | 11:23 AM
White Knight 04's Avatar
White Knight 04
I bugged into the tail light its self........How ya been shrink???
Old Nov 24, 2008 | 02:33 PM
White Knight 04
Jeff here is mine....
Old Nov 24, 2008 | 05:20 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
sorry, I didn't see you
Old Nov 24, 2008 | 06:37 PM
ballpeen's Avatar
ballpeen
"WOW",, I like it,, man they will see you, and anything helps Ive got a 96 led light bar on the back of mine I bought from the COP Shop
markthardy
Feb 4, 2017 07:33 PM
MJR
Mar 16, 2013 09:42 PM
rjheff
May 10, 2012 07:30 AM
groaning
Jun 30, 2011 06:48 PM
twilliams
Feb 26, 2008 10:24 PM
