Jackpot 4" slipons opinions
Old Feb 1, 2012 | 03:26 PM
  #61
plutnicki's Avatar
plutnicki
FWIW, if I can't figure out how to fund it all as a power package, I'm going to do the 4" slip ons first, then A/C and Power Vision at the same time, then the full headers last.
That's usually the order I've done and it's worked for me in the past.
Old Feb 1, 2012 | 03:44 PM
  #62
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by iclick
Just out of curiosity, could you use two QB's on a TD setup?
I would not recommend using 2 quiet baffles with true duals. This would be too restrictive and would retain a tremendous amount of heat in the exhaust system.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
  #63
hougz79's Avatar
hougz79
The only issue you may run into is the heat from the CAT could blue your right muffler. That CAT gets very hot and it's right in front of your muffler. Your left muffler should be fine, just something to keep an eye out for.
With my stock header on my 2010, my Rinehart slip-on blued pretty bad.
Old Feb 1, 2012 | 04:13 PM
  #64
plutnicki's Avatar
plutnicki
Really. Maybe I ought to hold off until I can do the whole power package (slip-ons, PV and A/C to help cool it all down), and then do the headers...
Just have to save up a little longer that way...
Old Feb 1, 2012 | 04:14 PM
  #65
Egldr05's Avatar
Egldr05
How do the 4" Jackpots fare on a bigger inch motor (120") with V&H Power Duals head pipe, too restrictive?
Thanks,
Rick
Old Feb 1, 2012 | 05:15 PM
  #66
DeneFXDWG's Avatar
DeneFXDWG
Default pt4u2nv...
Originally Posted by pt4u2nv
Why true duals if you are worried about performance ?
It's kind of a backwards way of thinking Rick and I'll tell you why. I got my jugs bored out and cams installed a couple of weeks ago. I chose the cams because of mainly I heard they had awsome sound. Got the scoot back from the shop and excitedly fired it up and couldn't really tell anything different from the way it sounded with the stock cams. I am running the stock cat headpipe remember Rick. So to hoepfully give me the sound I originally wanted I went with True Duals, am I going to notice any difference in performance, doubt it, really doubt it but I'm pretty well certain that it'll sound they way it want the SE204's to. Does this make sense? I would've went with Rineharts as first choice but couldn't justify just buying the Jackpots last season only to shelve them for mufflers that fit the specific Rineharts.
Old Feb 1, 2012 | 05:19 PM
  #67
DeneFXDWG's Avatar
DeneFXDWG
Originally Posted by Ronp42
Someone correct me if I'm wrong, but I believe the quiet baffles will help give back some of the performance you'll lose with true duals.
Correct....to a certain extent, don't want to choke it too much and Frank, (Dragos), Doc's Performance and Rush all said that to get the optimum performance out of the Rush TD's go with the 2" baffles.
Old Feb 2, 2012 | 01:47 AM
  #68
mike5511's Avatar
mike5511
Why don't you install a Quiet Baffle?
BTW, the QB setup is for use with exhausts with crossovers, so if you go with TD's you'll have to use a muffler with symmetrical baffling.
Thought about the quiet baffle, but to tell you the truth, after going from dresser duals back to stock header with 4" Jackpots, I just don't like the sound. Plus it drones some at certain cruising speeds. On level ground cruising down the road they sound fine. But I don't have much level ground here so I'm always "twisting the wick", thus I'm constantly hearing this roar from the right side only. It just hasn't grown on me yet. I still have my old dual mufflers. Almost sold them but decided to hang on to them and wait and see. Plus Jamie said going to the quite baffle would hurt my performance a little bit, probably not any worse than duals would. Maybe I should give it a try????
Old Feb 2, 2012 | 05:20 AM
  #69
TUCCI's Avatar
TUCCI
Video like pics are not a true representation but here's the 3.5" on a stock system minus the Cat's: This is without using the Quiet Baffle which will arrive on Friday.
Old Feb 2, 2012 | 05:23 AM
  #70
TUCCI's Avatar
TUCCI
usually there's an arrow in the center of a video, but click in the center of the pic above my sig pic and it will start the video.
