Airing up Rear Shocks
Old Jul 4, 2011 | 03:21 PM
b1rider's Avatar
b1rider
Default Airing up Rear Shocks
I recently purchased a new Limited and wanted to check the air pressure in the shocks. With my 07 Nomad you had to lift the rear wheel off the ground to check the pressure. In the manual it made no mention of having to do this. Can I check/add air pressure to the rear shocks without having to jack the rear wheel up?
Tx
Old Jul 4, 2011 | 03:26 PM
luc.who's Avatar
luc.who
My manual does not say I need to check it on a jack.
Old Jul 4, 2011 | 03:39 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Short answer, no.
Old Jul 4, 2011 | 03:53 PM
jpglide's Avatar
jpglide
No need to jack it up. Pick up a moco shock pump - makes adding air easy. Nipple is between your fender and left bag - at least that's where it is on my bike
Old Jul 4, 2011 | 05:39 PM
ocezam's Avatar
ocezam
Yeah, but that's only your bike. Everyone else's is under the fairing. Really a pain to adjust.
Old Jul 4, 2011 | 07:17 PM
Morris9982's Avatar
Morris9982
Maybe your's is under the fairing but all the touring bike's I've seen has it between the left saddlebag and fender, as does mine.
Note to the original poster: Be sure to use a suspension pump such as the one from HD mentioned. If you try to use a regular air fill like used for tires, you will over fill the system and risk damaging it. The volume in the system is very low and is not designed for being filled with systems used for tires. Not sure if you knew that or not so thought I'd mention it.
Hope this helps.
Old Jul 4, 2011 | 07:26 PM
Lost1's Avatar
Lost1
I have an '07 and mine's between the left saddlebag & fender.
To the OP- it doesn't have to be raised to check the pressure. Would also suggest you get the pump w/gauge either from HD or Progressive Suspension.
Old Jul 4, 2011 | 07:35 PM
PistonPuller's Avatar
PistonPuller
Say what?? I think its the other way around. Everyone else has the fitting between the rear fender and bag. Never heard of one under the fairing.
Old Jul 4, 2011 | 07:53 PM
IAMSWUTIAMS
Is it a Harley Ltd.?
Old Jul 4, 2011 | 08:02 PM
J2X's Avatar
J2X
On the RKC it is between the bag and fender on the left side as well.
