Handlebar 2011 Road King
Old Jul 9, 2011 | 07:47 AM
SeniorChief56's Avatar
SeniorChief56
Veteran: Coast Guard
been there done that with Heritage bars....they worked for me by getting rid of the upper shoulder pain. But the look of those bars on a Road King was not right to me. Went to 10" mini apes from Wild 1 and about a month ago had 16" apes installed. Go sit on a bike with apes, bet ya a tank of gas that you get apes!
Old Aug 17, 2011 | 12:55 PM
fiestman's Avatar
fiestman
2nd Gear
Default bars
What about no throttle cable on a 2011?do you need to modify the new bars? Thanks
Old Aug 17, 2011 | 02:08 PM
TW's Avatar
TW
I use Wild 1 14" bars on my Road King AND my Softail.
Old Aug 17, 2011 | 02:42 PM
Jon0807's Avatar
Jon0807
I just put on wild one 502's on mine and couldn't be happier. I needed longer clutch cable, brake line and control wires. The bars are notched for the TBW but no need for longer wires. I did it myself over a weekend and the most time consuming part was the internal wiring
Old Aug 17, 2011 | 02:43 PM
Jon0807's Avatar
Jon0807
Oh you will also need transmission fluid and possibly the transmission cover gasket if you chande out the clutch cable
Old Aug 17, 2011 | 03:22 PM
rlchristensenmd's Avatar
rlchristensenmd
Does anyone know if the 56902-08 bar will work on an 07 Road King? The bar is listed for 08 and later models.
Old Aug 17, 2011 | 05:01 PM
leicafish's Avatar
leicafish
Heritage Bars
I am 5'4"
Old Aug 17, 2011 | 08:48 PM
Bill OhioWeatherSucks's Avatar
I just installed these bars on my 11 RK this past Sunday, took me about an hour and a half no extra parts needed, Best $79.00 I've spent. These are the the bars that the police RK is built with and they are much more comfortable.
Old Aug 19, 2011 | 08:41 AM
CVORoadKing2013's Avatar
CVORoadKing2013
Hi I have a 2011 Road King and am looking at swapping out the Stock bar with the Heritage Style bar also. What I am not understanding is everyone talks about more pull back with this bar. From what I see in the chart Harley has is it is 2" less pull back from the stock road king bar but has 5" more rise
Handlebar kit bar diameter Tip-to-Tip pull back Rise base width knurl
55947-08 1 31.75 7.00 7.00 13.75 3.14
56902-08 1 31.25 5.00 12.00 11.50 3.14
Can someone please explain how it has 3more inches of pull back?
Old Aug 19, 2011 | 06:02 PM
Part Number Tip to Tip Base Width Pull Back Knurl
Center to Center Rise
(Tip-to-Base)
(Outside) 56941-09 34.00" 11.50" 3.25" 3.24" 4.00" .................................................. ....................56902-08 31.25" 11.50" 5.00" 3.14" 12.00"
