Second Round w/CFR Mufflers
Boxes came from the seller and last weekend I didn't have time to install the headers, so I just installed the mufflers on my Bub true dual headers. I went for a 50 mile ride and the bike is like crap again. I have a map for my PCV from Fuelmoto that is for my setup and it ran great with the knock offs. I did tweak a few cells for a couple of flat spots. I am going to try going back to the unaltered map this evening from FM, but I am still going to guess it will not make a difference.
The bike seems to shake real bad and only likes higher rpms. The mirrors, handlebar and rear turn signal bar rattle real bad in low rpms. I put the two different mufflers side by side and the only thing I noticed was the diameter of the holes in the baffles. The CFRs have a honey comb like baffle that run around the perimeter inside of the muffler, and the real CFRs have smaller holes than the knock offs. Not a huge difference, but noticable. I believe that the ko's are louder, too. Maybe because of the size of the holes in the baffle.
Anyway, would anyone happen to know what could be causing this vibration with both sets of real CFRs I have tried? I plan on installing the CFR headers soon, and I have a Autotuner for the PCV I just pruchased from Dennis here on the forum to add to the headers since they have O2 bungs. I have not heard of others experiencing this with CFRs and other headers, so it can't be the Bubs making a difference. Maybe a good tune with the AT will cure the problem.
I've read from a few people that have had motor work done, they cannot get their motors to run right with CFR's. Something about them being too wide open, no back pressure.
What have you had done to your motor?
Never mind, just saw your signature.
Kind of funny I am running two different dual headers, but the Bub and the CFR rear left headers look exactly the same. The front headers are extremely different. CFR is straight all the way down past the cam plate. The Bub has a bend up and over toward the end below the passenger board.
