17" vs 18" front tire
Old Jul 11, 2011 | 09:31 AM
rockenharleydude's Avatar
rockenharleydude
Stage III
Default 17" vs 18" front tire
Thinking of going to chrome wheels on my 09 Street Glide. If I go with the 18" front wheel like on the newer bikes does it change the handling or ride any? Seems like the lower profile tires would ride harder to me.
Old Jul 11, 2011 | 09:55 AM
NAUIdvr1's Avatar
NAUIdvr1
I changed mine to an 18" from a 2010 SG, and didn't notice any difference. The only reason I did this is 'cause I needed a new rear tire last year & found a full set of new take off rims & tires for the same price it would have cost me for the rear tire & mounting. So I bought the set & did the swap myself. Now when I need new tires, I just take in my spare set of rims & have them mounted, then take home & swap them out.
Old Jul 11, 2011 | 10:01 AM
capnlovr's Avatar
capnlovr
I don't think you will notice any issues but I would do a search because there has been tons of posts about this topic.
Old Jul 11, 2011 | 10:09 AM
2004Sierra's Avatar
2004Sierra
I went from a 17" to a 18" front rim on my Road King.
The 18" made little to no difference in ride and handling, but I think the 18" looks better.
When I installed my chrome front end I used SE heavy fork oil and that made much more difference in ride than the 18" rim did.
Old Jul 11, 2011 | 10:10 AM
carpetride's Avatar
carpetride
You won't have any problem. The 130mm or 140mm 18" tire has plenty of side wall height for a smooth ride. The diameter will be very close to the stock tire so handling won't be affected.
Old Jul 11, 2011 | 10:31 AM
07DDreamHD's Avatar
07DDreamHD
I went with an 18" front wheel on my 09 SG. I also went with a 17" wheel and 20 mm tire on the rear. My complete set-up should be in next week. I researched all this for a few weeks before I made my decision. From what I gathered, this will not cause much change at all in the ride.
Old Jul 11, 2011 | 12:35 PM
coolerman69's Avatar
coolerman69
i went to 19" with absolutely no noticeable difference. Also 19's are easy to find.
Old Jul 11, 2011 | 09:22 PM
cooper57M's Avatar
cooper57M
i went from 16 to 18 , the narrower tire sidewall on the 18 made the ride a little stiffer. Im sure with 17 to 18 would be even less perceptible.,
ballbreaker69
Aug 28, 2017 10:32 AM
GKstreetglide
Mar 17, 2010 08:44 PM
neano62
Jan 5, 2010 07:52 PM
stevepacman
Jan 17, 2009 08:31 AM
pingman68
Aug 6, 2008 07:30 PM
