Center Stand Recommendation?
Old Jul 15, 2011 | 03:54 PM
dnitram's Avatar
dnitram
Question Center Stand Recommendation?
Looking at a center stand for my 2011 RKC and it seems you need to specify whether or not it's standard height or lowered, like on a RG. I do have 12" shocks, though the RKC comes with 13" stock. Every once in a blue moon I put the 13" shocks on for a long ride. Does anyone make these where one brand will adjust between a 12" and a 13"?
Old Jul 15, 2011 | 08:03 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i know someone does, not sure if it was harley or maybe rivco.saw one it had a bolt on the bottom of each legg.
Old Jul 15, 2011 | 09:03 PM
Morris9982's Avatar
Morris9982
The one from Harley has adjustable feet.
Old Jul 15, 2011 | 09:30 PM
dnitram's Avatar
dnitram
Thanks! I'll see what they have to offer. I appreciate it.
Old Jul 15, 2011 | 09:33 PM
Ultra89Rider's Avatar
Ultra89Rider
The Harley one is the one I have on my '09. I love it.
It is adjustable. I can make it where the rear tire is off the ground or not.
The other Aftermarket ones do not adjust. You will need to choose how it will sit.
After that, your stuck with it.
Old Jul 15, 2011 | 09:44 PM
vistavette's Avatar
vistavette
I have the EZ-UP stand and it's great but you'll have to decide on which model to pick; the lower or regular. Since you usually use the 12" shocks it seem that you should just go with the model of any manufacturer you choose for that set up knowing that it won't function with the 13" shocks. Of course if you can find one that will work with both that would be great.
Old Jul 15, 2011 | 09:54 PM
2010 Raffel Road King's Avatar
I put the HD on my Road King immediately after I got it and love it. The adjustable height feature is really nice. I've got mine so the rear wheel just comes off the ground.
Old Jul 15, 2011 | 11:56 PM
Punjabi Rider's Avatar
Punjabi Rider
With lower shocks you might have problem with speed bumps and scraping on tight turns. I have one on my 07 UC stock height from HD and it still scrapes on speed bumps and tight turns if I'm not careful,other then that it's great for cleaning or working on the bike.
Old Jul 16, 2011 | 12:16 AM
Ultra89Rider
That may be true with the old frame. The OP has a 2011. I have a '09 with the new frame.
I can scrape the running boards in turns and don't touch the center stand at all.
Old Jul 16, 2011 | 06:01 AM
tj316's Avatar
tj316
I'd go with yhe e zup , you can put it on the center stand while sitting on the bike which is a nice feature
