Octane Question
Old Jul 18, 2011 | 07:40 PM
07RoadHawg's Avatar
07RoadHawg
Originally Posted by SteveO
Don't forget to put in the -12-15% lower BTU for ethanol. Takes more throttle and more pounds of fuel to get the same BTU/HP as non ethanol gas.
Only about 1/2 right. Yes, ethanol has less energy (BTU), but that does not equal less power. It does not take more throttle, but it does take more volume of fuel for a given throttle position. In fact, it's proven day after day that huge HP can be made with ethanol due to it's high octane rating and ability to support increased compression. It just takes a lot more fuel and a motor set up to burn it.
Old Jul 18, 2011 | 08:34 PM
fabrik8r's Avatar
fabrik8r
Originally Posted by 69cj
Then burn regular and good luck. It's you'r bike not mine. For a buck a tank full it's called being fuelish.
I wasn't even taking a stand on octane, one way or the other, but now that I'm here, if I want to burn regular, I don't need luck to do it, stock compression doesn't demand higher than 87 in most cases. If your not pinging, no need to bump up the octane. Now if you wanna talk foolish, riding your grand daugter around in shorts qualifies.
Old Jul 18, 2011 | 08:41 PM
LarryLives's Avatar
LarryLives
I run high test, the bike loves it and so do I. Plus, with all the $hit they are adding to fuels now a days, I would think the hi oct is safer. JMO...
TC_Sportster
Mar 24, 2015 07:54 PM
Mac daddy 103
Apr 13, 2014 07:08 AM
Bob99
Sep 21, 2009 09:15 AM
stinkyshoes65
EVO
Apr 21, 2008 03:40 AM
carlo
Feb 6, 2008 08:41 AM
